I need to swap some of my wires/pins in my NA6 ECU harness connector/terminal to wire up a variable TPS. Specifically 1N to 2M and 2L to 2K.
I'm having trouble removing the pins from the terminal as I need to re-use them. Anyone know how to remove the pins from the terminal keeping them intact and attached to the wire?
Thanks
Brendan
Remove ECU Pins
Re: Remove ECU Pins
Fine flat blade screw driver in from the non wire side of the plug. You have to push a little tang down for memory then they side out.
- plohl
Re: Remove ECU Pins
there is also a little tab that runs the length of the back of the connector - one for each bank of pins. You will be able to see the clips looking side on. You need to un-clip this tab as it prevents the pins from being removed.
plohl
plohl
Re: Remove ECU Pins
Yep thanks all makes sense. Im still having trouble releasing the tab but I was pushing up. I'll push down now (from the ecu side) and see what happens.
Thanks
Thanks
Re: Remove ECU Pins
Still having trouble - starting to give me the shits now haha
Re: Remove ECU Pins
It's up or down just keep fiddling. Once you get one the other should only take a minute. Are you keeping very slight tension on the wire?
Re: Remove ECU Pins
Yea trying to but its pretty fiddly
https://www.flyinmiata.com/support/inst ... rewire.pdf - This says to do it from the wire side but im still not having luck with that either.
Re: Remove ECU Pins
Got It!
Just the same as that guide and push up when its in!
Yay! Thanks guys.
Yay! Thanks guys.
