Okibi's SE
bootz
Re: Okibi's SE
Postby bootz » Fri Apr 11, 2014 1:59 pm
kenson wrote:Haha I could see this coming!
Yep I made 171 HP atw in different conditions - I still haven't scanned in my dyno chart yet.
The important thing, is we're getting pretty consistent numbers for similar mods @12 psi.
The dyno we're using is known to report low and I've heard phrases like "heart breaker".
HP number lovers have gone to other hub dyno's in Perth and have seen a 20% difference.
Saying dynos report low or optomistic is a crock of sh*t - like saying my scales are a heart breaker because they say i weigh too much.... measuring instruments should be accurate, consistent, reliable etc etc.
Re: Okibi's SE
Postby NitroDann » Fri Apr 11, 2014 2:02 pm
But dynos aren't.
Sorry.
Whether or not the car pulls itself up the front roller and off the rear one is worth up to 15kw straight up for example. Big power cars are affected less by this effect. Slow ramp rates make this effect smaller due to more friction less intertia being used as a ratio etc etc
bootz
Re: Okibi's SE
Postby bootz » Fri Apr 11, 2014 2:07 pm
NitroDann wrote:But dynos aren't.
Sorry.
Whether or not the car pulls itself up the front roller and off the rear one is worth 15kw straight up for example.
True, they are only measure relative changes ie. dyno, change setting, dyno again, any difference???
And you better do it with same day, equipment, operator for it to have any relevance.
kenson
Re: Okibi's SE
Postby kenson » Fri Apr 11, 2014 2:27 pm
Trying to stay away and not mess up Dave's thread but yep, they're tools for tuning.
What I was trying to say is:
1) Two cars similar mods
2) Similar weather conditions
3) Same operator, same dyno
Consistent and similar values = good. Then there are other factors to worry about like slippage etc.
Dann's got it with the stopwatch.
Swordfish
Okibi's SE
Postby Swordfish » Wed Apr 16, 2014 3:13 pm
Here's the animal
Good day out at the Perth RAC auto test double skid pan.
... And Dave had a good day out too result wise ;)
Dave
Ti SE
(WA Based)
Re: Okibi's SE
Postby Okibi » Wed Apr 16, 2014 9:31 pm
edit - DOH!
Thought it was Tesco's photo :
Nevyn72
Re: Okibi's SE
Postby Nevyn72 » Sun Apr 20, 2014 10:11 am
Was trolling around the net on a lazy Sunday morning and came across a replacement steering wheel to suit airbag equipped NBs.
Now knowing you like a bit of Carbon Okibi I thought this might tickle your fancy for a future upgrade, just don't look at the price..... :shock:
http://www.ilmotorsport.com/shop/articl ... c5c6757a6f
Re: Okibi's SE
Postby Lokiel » Sun Apr 20, 2014 6:47 pm
I looked Image
- it's the airbag that demands this price and because it includes an airbag it probably can't be shipped since it's classed as an explosive device.
Nice find though.
sailaholic
Re: Okibi's SE
Postby sailaholic » Sun Apr 20, 2014 7:34 pm
It can be shipped it would just have to go sea freight or shipped as a dAngerous goods. You can air freight dangerous good but it's extra work and cost (and not provided by your basic shippers)
Re: Okibi's SE
Postby Okibi » Mon Apr 21, 2014 12:00 am
:cry: ugly carbon makes babah jebus cry.
Nevyn72
Re: Okibi's SE
Postby Nevyn72 » Mon Apr 21, 2014 7:50 am
Okibi wrote::cry: ugly carbon makes babah jebus cry.
So I guess that means you don't like it them? :P
Saves you a LOT of money in that case..... :wink:
Re: Okibi's SE
Postby Okibi » Sun Apr 27, 2014 9:23 pm
Now the BEGI intake is in and the car is tuned i've had time to spray my FM throttle body intake.
A nice silver intake would have suited my old NB but with the black on black on black theme emerging the shiny silver elbow stood out like dogs balls.
And undercoat of Black hi temp paint then some wrinkle finish paint
I sat it in the BBQ for half an hour to bake
Here is it all back together
White I had the spray cans out I decided to paint my cusco radiator shield thingo.
After spending hours polishing all the anodizing off this once, I felt bad attacking it with sandpaper
Nevyn72
Re: Okibi's SE
Postby Nevyn72 » Mon Apr 28, 2014 8:11 am
Looks good! :mrgreen:
Now all you've got to do is the cam cover, intake plenum, strut tower brace and radiator cap and you wont be able to find anything at all if you break down by the road at night! :P
Re: Okibi's SE
Postby Lokiel » Mon Apr 28, 2014 1:11 pm
You missed a couple of bits:
1. The top blue section on the EBC:
2. The thermostat housing:
Also, consider adding an acrylic clearcoat to the radiator panel to protect the paint from chipping - that panel seems to get beat up no matter how careful you are.
Re: Okibi's SE
Postby Okibi » Mon Apr 28, 2014 8:30 pm
Yup already plan on copying your work with the mac valve.
I have a black thermostat housing with maruha motors sensor spacer sitting in the shed for when I can be bothered installing my FM twincooler.
I also have my mazdaspeed strut brace in the shed so I can truly be your disciple. I just need to rob a bank so I can fly my car to Automotive Plus and NitroDann :mrgreen:
... and I already put a few coats of clear on that plate.
Users browsing this forum: Google [Bot] and 7 guests
