Roadrunners SE
Roadrunner
coyotes after you
Re: Roadrunners SE
Postby Roadrunner » Mon Mar 31, 2014 4:52 pm
When I upgraded the headunit, I also installed in the boot an pioneer old amp I had from years ago.
Considering it was powering the stock speakers the sound quality increase was surprising, but eventually I wanted something better.
This was running fine until recently when the amp finally gave it up (im thinking it was 12 years old?). Just the excuse I needed :lol:
I set out looking for a half decent 4channel amp and some good splits for the front.
Got quite a good deal from a local Pioneer independent on a 4channel amp and a surprising deal on a pair of Focal splits.
I mounted the amp to an angled board on the battery cover. Its still easy to remove if I need access to the battery etc.
Its ok for the moment but I will revisit this as im not totally happy with the mounting location (juuuust doesnt fit in the tunnel)
The door speakers were a bit more elaborate.
First the wiring is difficult. The grommet through to the door is actually a plug. Theres no room to run a new cable through there. I considered running the cables out through a grommet into the engine bay through to the front fenders and into the door grommet that way but seemed it too much effort. So I simply ran new cables either side of the plug and soldered to the factory cables (figured 6inches of smaller cable would be fine)
Also the factory cable is simply spliced to two cables for the speaker and the tweeter, so the full range is going to both midrange and tweeter.
Door skins off
Theres a huge amount of depth in the door cavity. 110mm!
The door hole is also 8inchs wide so made some baffles from MDF with some foam to stop any rattles etc
The new tweeters mounted to the factory mount via super strong double sided tape.
This is the factory speaker mount that the 5x7inch speaker sat in. It forms a water protection as well so I modified these to mount inside the cavity the protect the new speakers
Mounted inside with double sided tape completely sealed to the door
One mistake was forgetting to leave room for the door hinge stopper (or whatever it is called)
When I closed the door it extended out and hit the rain cover.
I cut the cover back to avoid knocking it off completely
Mounted the crossover in the door pocket and ran the cables under the skin into the door
All mounted up
With the door skins back on you cant see that anything is different.
The sound though, WOW! I hear a lot of people say its not worth upgrading the system in a convertible but the sound difference is huge.
At less than 80ks its massively better than the factory setup, on the freeway you've got to push the volume up (understandably) but still quite decent and the clarity is still excellent at higher volumes.
Was it worth the money? Yes, Its not a comp spec or high end setup for audiophiles but its a massive improvement over factory. I would highly recommend doing it.
MeepMeep
Roadrunner
coyotes after you
Re: Roadrunners SE
Postby Roadrunner » Fri Apr 04, 2014 8:54 am
So this came the other day:
MiataRoadster Short Shifter
Quite easy to install. Getting the factory bushing out of the turret was a mission though, ended up snapping coming out but its not used again so no problems.
Also the black cup on the end of the stick needs to be put in first, not last like the instructions say. I couldnt get it past the pivots, so pulled the bushing out and dropped it in.
Went for a drive and its firm. Initially had to use some force to change gears but after a short drive around the block it started freeing up, or my arm grew some muscles :lol:
Gear changes now feels very direct and solid. Changing gears is a breeze. Reverse is easy to find, no more crunching gears.
Very happy with this mod!
Next I have to hunt down whats causing my squeaking clutch pedal issue. Its embarrassing in quiet carparks :lol:
MeepMeep
Nevyn72
Re: Roadrunners SE
Postby Nevyn72 » Fri Apr 04, 2014 11:30 am
Congratulations!.... At least yours has shown up..... :roll:
Did you opt to delete the shift boot?... or were there more parts in the kit that you've shown?
Re: Roadrunners SE
Postby Okibi » Fri Apr 04, 2014 12:51 pm
Glad you like it, I think they're almost a "must do" mod for the 6 speed.
Roadrunner
coyotes after you
Re: Roadrunners SE
Postby Roadrunner » Fri Apr 04, 2014 2:06 pm
Definitely recommend this. Don't know how the other half will like the firmer shift, but she should get use to it
My upper boot is in really good nick so opted out of that. Didn't bother with the extension piece either as I think it would make using the H/U too hard.
It comes with the bushing and gaskets already assembled on the stick, the only other items loose in the bag are the three longer screws and the lower black pivot bushing and some thread lock
And the tracking on the USPS is terrible. It only updates after it has arrived at the next destination. I was getting worried because it said it was sitting at L.A for nearly two weeks, but it was actually in transit to Sydney during that time.
Mine still hasn't updated to delivered on the site :roll:
MeepMeep
Juicy HiC
Re: Roadrunners SE
Postby Juicy HiC » Fri Apr 04, 2014 2:19 pm
My wife didn't even notice I'd changed it in mine. Definitely worth it.
Roadrunner
coyotes after you
Re: Roadrunners SE
Postby Roadrunner » Sun Apr 06, 2014 9:10 pm
Juicy HiC wrote:My wife didn't even notice I'd changed it in mine. Definitely worth it.
Really? I admit it's a much nicer shift but definitely requires quite a bit more force to change gears.
I wonder if I have assembled something wrong. Maybe not enough grease? It says to use white silicone grease, I only had it in a spray can so just sprayed heaps of it on the parts it says to.
Should I get some solid grease and re-grease it all?
MeepMeep
WASP
Re: Roadrunners SE
Postby WASP » Mon Apr 07, 2014 12:36 am
Oddly enough, one of the things I dislike about my SE is the 6 speed box, much preferred the 5 speed in my old NA8
Steven
Nevyn72
Re: Roadrunners SE
Postby Nevyn72 » Mon Apr 07, 2014 9:46 am
While I would suggest it would probably be better if you went back in and packed the proper grease (thick grease is very different to spray on lube) this is not what is likely making it harder to shift.
The short shifter kit works by moving the fulcrum of the mechanism. That is you get a shorter throw by effectively moving the pivot point of the lever. The side effect of this is that it requires more effort on the 'push' end of the lever to achieve exert the same force on the other end of the lever, hence it becomes harder to achieve the result on the shift mechanism in the gearbox. This is the main reason why short shifters are 'harder' to use. :wink:
Juicy HiC
Re: Roadrunners SE
Postby Juicy HiC » Mon Apr 07, 2014 10:25 am
Only used spray lube on mine. So far so good
Roadrunner
coyotes after you
Re: Roadrunners SE
Postby Roadrunner » Mon Apr 07, 2014 2:55 pm
Sweet, thanks for the responses.
I had a proper short shifter in a pulsar many many years ago and I remember it being harder to shift due to the change in pivot point. So I assumed it was normal.
Maybe JuicyHiC's wife is stronger than my wife :lol:
I might re-pack is with thick grease just for the hell of it/piece of mind. It was pretty easy to get to.
MeepMeep
Roadrunner
coyotes after you
Re: Roadrunners SE
Postby Roadrunner » Fri Jul 18, 2014 5:35 pm
So I finally got around to doing my relocated washer bottle.
After removing the factory one, mainly because it looked ugly where it's sat in the SE, I almost didnt bother with another one, as iv ran with out a bottle for about 6 months now and not once needed to spray the windscreen (and also didn't want to, as the roof is down more than its up)but figured I better put something back in.
Not willing to pay $150 odd for a Nopro bottle, I picked up an old lawnmower fuel tank for nothing that was rough the right height.
I drilled a 20mm hole in one end for the pump to fit into. I had to lay the pump sideways so it didn't sit up too high. I don't think this matters.
To hide the bottle and make it not look so much "dodgy home made" I found some flat offcut of colourbond and bent it to hide the top and the back side.
I didn't want to try to cut the ends to fold them back for the sides (re: lazy), so I just kept the colourbond a few inches longer either end so you couldnt see the bottle from an angle
Cut a hole for the neck to go through and paint it with some black colourbond spray I had lying around to make it look all 'professional' lol
Using good double sided tape to stick the bottle in the right spot, then taped the colourbond onto the bottle.
Extended the plug from the factory spot back through the wall and along the cowl to the new spot.
The nozzle hoses can actually be reversed from left to right if you carefully pull out the clips. The locater holes are mirror image on the drivers side, you just need to turn the plastic couplings around. Done, no need to extend the hose, though you could easily if you wanted.
I think it looks great and cost nothing using junk lying around!
MeepMeep
Re: Roadrunners SE
Postby fastfreddygassit » Fri Jul 18, 2014 8:29 pm
That is an awesome mod!
I love it, kudos to you :NETPOINTZ: :NETPOINTZ:
:mrgreen:
Roadrunner
coyotes after you
Re: Roadrunners SE
Postby Roadrunner » Sat Jul 19, 2014 6:51 pm
Next up is something I'v been contemplating for a while now.
I like the look of the factory SE Racing Hart rims, and I also like white rims.
The cars previous owner had gutter rashed two rims a fair bit, so I searched websites for ages looking for 17x7inch white rims, then just 17x7 inch rims in general that I could spray up. There is not much out there that I liked, and the ones I did like were 5stud or the offset was completely wrong! The odd ones I found that I liked were basically the same design as the Racing Hart rims, so I decided to just get mine ground back and sprayed up.
Personally I am really happy with the result.
The lip was ground back very nicely, you wouldn't even notice its been lipped.
I also went to my first ever track day too. What a blast!!
It was at the Marulan Driver Training Centre near Goulburn, tight twisty track and the fastest you can get too down the straight is about 100kph so thought it would be a good track as a starter.
Definitely looking to do a couple more of these every now and then!
Myself and my wife shared the car for the day and she enjoyed it as much as I did. Lots of fun and the car didn't miss a beat all day or the 4hour drive home!
MeepMeep
Roadrunner
coyotes after you
Re: Roadrunners SE
Postby Roadrunner » Wed Jul 30, 2014 5:58 pm
fastfreddygassit wrote:^^^^^
:mrgreen:
Thanks mate! :D Done over 500ks around the country side since putting it in and still sitting snug in its spot. Very happy for a dodgy knock up job.
Now I need new wiper blades :lol:
MeepMeep
