Exocet Australia wrote:I can build you something that'll hold your bike that's removable. Won't cost you an arm and a leg either. Wouldn't be designed for towing a trailer
Watching with interest...
I had a tow bar custom made for the GM, to tow a trailer. Worked a treat, and still working on someone else's car.
It was as heavy as buggery, bit of a problem for a track car, but the weight was mostly in the tongue (it was a modified junkyard HR unit), and the tongue was removable - problem solved!
Exocet Australia wrote:A permanent frame mounted to the tow hook bolt mounts would only be 5-8kg. A frame could then slide in and be held with pins.
I'm back at my workshop and just looked under the NB. I can't see anywhere reasonable that a conventional towbar could bolt to. Still doable, just doesn't have mount points like the NA does
