NC WATER LEAK
Hurricane
Vehicle: NC - LE
NC WATER LEAK
Postby Hurricane » Thu Apr 03, 2014 9:22 pm
Need help with a water leak I am having front passenger side. I have cleaned rear rain rails where my previous leak came from but now when running the aircon get a drip at the passenger feet. After driving home tonight in torrential rain got a constant drip which has saturated the mat. Is there a tube I need to clean at the front or would this just be the aircon tube being block. Cheers
:NC: :NC:
2005 Limited Edition Velocity Red with plenty of bling.
aka_juffa
Re: NC WATER LEAK
Postby aka_juffa » Fri Apr 04, 2014 7:44 am
Did you have the air-cond on last night? If so then check out the air-cond drain pipe. If not check your soft top drain points.
Disclaimer: I do not own an NC, and therefor the above information could be a load of crock.
J.
Users browsing this forum: No registered users and 21 guests
