Would someone mind explaining the intricacies of a BOV.I am using the std one. What, if any are the benefits of changing a BOV.
Steven
TTT wrote:TL:DR? if you have a stock one and don't worry about changing it.. there is no benefit.
NitroDann wrote:N/a cars runs about 13 parts air per part of fuel by weight at full throttle.
Turbo cars run 11.x parts air depending on setup.
Crapweasel wrote:TTT - Both. (Damm you Dann)
It's one of five "weak" areas on a stock SE.
BOV, rubber intake piping (swells, and can split under boost), intake (restrictive), exhaust (restrictive) and intercooler (prone to heat soak).
If the car is only being dríven normally with the occasional mild run through the twisties, then these aren't issues. But if you plan on tracking the car, or want more performance for spirited driving then these are the first areas to address, which then reveals the ECU easter egg.
Most call it the sudden switch to open loop fuel, or the afterburner effect, I refer to it as "slow, slow, slow, DEAR HOLY MOTHER OF GOD!"
