dreaded mistake of removing reverse linkage bolt
MXO00V
Postby MXO00V » Sun Mar 16, 2014 3:11 pm
ok accidentally removed reverse linkage bolt instead of fill plug on a 6speed NB8B gear box
have gearbox out of car bell housing split off trying to sit linkage back in for reverse gear having trouble keeping it there when putting bell housing back on and slide bolt back in
ANY TIPS? :shock: :|
Re: dreaded mistake of removing reverse linkage bolt
Postby 93_Clubman » Sun Mar 16, 2014 4:13 pm
Here's how this issue was recently approached:
viewtopic.php?f=29&t=61664&start=45
MXO00V
Postby MXO00V » Sun Mar 16, 2014 6:25 pm
I've got my gear bell housing off just having trouble getting the linkage bit to sit and stay there while putting the slide in
Have tried grease and vaso
Sent from my GT-N7105T using Tapatalk
Aussie Stig
Stig
Postby Aussie Stig » Sun Mar 16, 2014 10:08 pm
A nightmare.
Postby Okibi » Mon Mar 17, 2014 12:16 am
Sorry can't offer any advice :cry: when I was putting my exhaust on, I grabbed a marker pen a wrote a note for any mechanic who might consider undoing it.
BPTravis
Postby BPTravis » Mon Mar 17, 2014 9:30 am
Whoa, now I'm scared to remove bolts on my gearbox haha
Does the box still work with out it?
Using Tapatalk
deviant
Postby deviant » Mon Mar 17, 2014 11:01 am
Nope. When that bolt is removed a pile of witchcraft inside the gearbox falls out of place.
MXO00V
Postby MXO00V » Mon Mar 17, 2014 6:51 pm
I wouldn't risk it the linkage piece is just sitting in the gear box could and probably would bounce around and jam the gearbox
MXO00V
Postby MXO00V » Sat Mar 22, 2014 2:30 pm
To anyone that has this problem Make sure slide and hole through linkage is smooth and clean of any bers
use supa glue to hold linkage in place on top and bottom
Then bellhousing back on and put slide back in and should be OK
Mine is all good :D
Users browsing this forum: No registered users and 90 guests
