Very nice Danny, need to see it in place to get a better idea of how it all lines up and really appreciate the effort you've gone to.
The fabrication is just mind blowing! I can't get over it!
- orx626
- Vehicle: NC - Rotary
Okibi wrote:Very nice Danny, need to see it in place to get a better idea of how it all lines up and really appreciate the effort you've gone to.
Apu wrote:The fabrication is just mind blowing! I can't get over it!
Thanks guys.
The past week has seen more work on the water pump assembly and subsequent plumbing progressing further. The water pump mounting bracket has been zip tied in because the hoses will dictate its final position. A remote mount oil filter head is positioned just forward of the water pump assembly.
There is a good amount of clearance between the heat exhanger and the water pump assemblies.
All the dash 20 coolant lines have been completed. This line is from the engine to the radiator.
From the radiator to the water pump.
From the water pump and back into the engine.
The forward mounting of the front splitter/diffuser has also been sorted.
My next design job is the intake plenum/filter housing.
- 16bit
sheet metal plenum? or are we looking at million dollar billet?
- orx626
16bit wrote:sheet metal plenum? or are we looking at million dollar billet?
No boost, no billet James.
- plohl
orx626 wrote:16bit wrote:sheet metal plenum? or are we looking at million dollar billet?
No boost, no billet James.![]()
Definitely pre-preg carbon hey danny
plohl
plohl
- 16bit
balls.
- orx626
plohl wrote:Definitely pre-preg carbon hey danny
Oiiiii! Who's funding this thing?!?!
NC Track Car - In the Build
The tax man!
+1 for pre peg awesomeness. Though it would almost look out of place in the hand fabed perfection of the rest of the engine bay.
- orx626
sailaholic wrote:The tax man!
The tax man doesn't fund sh1t! I've never had the tax man give me money without me deciding to spend it first!
sailaholic wrote:+1 for pre peg awesomeness. Though it would almost look out of place in the hand fabed perfection of the rest of the engine bay.
Thanks Nick. There may well some pre-preg awesomeness before the car hits the track.
- 16bit
aerodynamic awesomeness?
Danny I need to discuss some custom radiator shroud work
- orx626
16bit wrote:aerodynamic awesomeness?
I hope so...no...I expect so....AMB Aero is on the job!
This will be an interesting aero project as one can't just go and wind up the the boost to offset an increase in drag (resulting from an increase in downforce). The aero has to be efficient on this car for it to be competitive (ignoring the competancy of the driver of course
- orx626
Magpie wrote:Danny I need to discuss some custom radiator shroud work
Of course.
- orx626
No progress actually on the car this week, but I did get the intake plenum/air box design sorted.
This is the whole assembly which includes a K&N panel filter that's sandwiched between the two halves. The latches are the same ones that I'm using to tie the ducted heat exchanger assembly together.
Front View
Top View
Bottom View
Side View
The fixed section of plenum with the filter installed.
The fixed section of plenum with the filter removed.
The removable plenum section.
If all goes to plan the rest of the oil/coolant plumbing will be finished by weeks end. Hopefully then the wiring can begin. I expect it to take a couple of weeks to get the materials in so that the intake plenum can be fabricated.
Front View
Top View
Bottom View
Side View
