NA8 Start Up Procedure
myredmx5
Postby myredmx5 » Wed Mar 12, 2014 10:07 pm
My NA8 won't start first time.
Is the fuel pump supposed to pump when the key is switched on as mine doesn't but does on the second and subsequent times.
What do I need to check?
Re: NA8 Start Up Procedure
Postby 93_Clubman » Wed Mar 12, 2014 11:13 pm
This started the same way:
viewtopic.php?f=55&t=46425
Also, failing 'Fuel Inj' relay in engine bay fuse box can have a similar affect.
myredmx5
Postby myredmx5 » Thu Mar 13, 2014 9:07 am
Is the fuel pump supposed to pump when the key is switched on before engaging the starter motor?
ralt
Postby ralt » Thu Mar 13, 2014 9:29 am
Hi.
Yes as soon as you turn the ignition on the pump starts to pressurise the fuel rail.
Postby 93_Clubman » Thu Mar 13, 2014 10:02 am
As Ralt says, but it won't necessarily be audible - it isn't on my NA8, which hasn't been changed from factory in that area.
Btw, thought you were indicating above it was audible on second & subsequent ignition turns.
myredmx5
Postby myredmx5 » Thu Mar 13, 2014 5:55 pm
ralt wrote:Hi.
Thanks 'ralt'. What do I need to look at to fix this?
myredmx5
Postby myredmx5 » Wed Apr 02, 2014 10:59 am
93_Clubman wrote:As Ralt says, but it won't necessarily be audible - it isn't on my NA8, which hasn't been changed from factory in that area.
Here's a fresh explanation.
Switch ignition key on = no sound from pump = try to start = does not fire within 5 seconds = switch ignition on = can hear the pump = try to start = does not within 5 seconds.
I go through this procedure several times and then it fires up.
Are there any items I should check. I have removed the pump and replaced the filter and there appears to be no blockages at those points.
Postby 93_Clubman » Thu Apr 03, 2014 10:02 am
93_Clubman wrote:This started the same way:
myredmx5
Postby myredmx5 » Thu Apr 03, 2014 12:14 pm
Tried substitution of said relay with no effect.
Postby 93_Clubman » Thu Apr 03, 2014 2:24 pm
myredmx5 wrote:Tried substitution of said relay with no effect.
What about checking if the so called 'black wire' issue is present as per the above link, ie: viewtopic.php?f=55&t=46425
It's also possible there's an intermittent issue with the fuel pump relay under the dash on the driver side.
Might also be an issue with ECU - Conti in Darwin had an onging issue with his NA8 Clubman, which he finally identified as ECU components: viewtopic.php?f=73&t=41675&p=535710#p535710
Also worth checking all earth points.
project.r.racing
Postby project.r.racing » Thu Apr 03, 2014 9:22 pm
pump in tank is buggered or wiring in tank is buggered.
Users browsing this forum: No registered users and 105 guests
