Braided clutch line length
Tight wad racers
Postby Tight wad racers » Mon Mar 10, 2014 5:31 pm
Finally sorted the clutch master and slave cylinder woes.
May replace existing hard and flex lines with a single braided hose, any recommendations on length to use?
sailaholic
Re: Braided clutch line length
Postby sailaholic » Mon Mar 10, 2014 5:58 pm
Mx5 plus have them on the shelf.
Postby hks_kansei » Mon Mar 10, 2014 6:08 pm
http://www.ebay.com.au/itm/30m-Measurin ... 634&_uhb=1
Length of rubber hose + length of hardline (or the distance needed when you ignore the weird spirals)
Order a little longer than needed, any excess can be clipped out of the way, but if it doesn't reach you're stuffed.
emily_mx5
Postby emily_mx5 » Mon Mar 10, 2014 7:14 pm
For my NA had one made up to exact length of the stock units.
The guy at ENZED said that is the best way as Mazda must have put in those "weird spirals" for a reason.
For my NB I will be getting the one from MX5 plus, as its much cheaper than getting one made up.
sailaholic
Postby sailaholic » Mon Mar 10, 2014 8:39 pm
Dosent the stock one run from drivers side to passenger side and back again on a Na?
wun911
Postby wun911 » Mon Mar 10, 2014 8:49 pm
What does the spiral do exactly?
every ounce counts
Hjt
Postby Hjt » Mon Mar 10, 2014 10:40 pm
Also for the people who don't know already...you can make the hardline that OEM fit between the master > slave and delete the rest.
Cost $0.
Users browsing this forum: Bing [Bot] and 3 guests
