What lights should come on during ignition ?
booki89
Postby booki89 » Sat Mar 08, 2014 12:28 am
Hey all,
I have a 94 NA8, and when i turn the key to ignition, only brake and one other light come on the center. Should there be a engine light coming on during ignition? Looks like there are 4 spots for lights, and from memory I only have two...
Also there is a light near my cup holders that comes on when I turn my headlights on, is that meant to be there?
Re: What lights should come on during ignition ?
Postby 93_Clubman » Sat Mar 08, 2014 10:11 am
'93 ADM NA8 here - 'Charge' & 'Brake' warning lights come on in the instrument binnacle when the ignition key is turned. If you've got OEM radio-cassette then the radio-cassette clock will also light-up. When the head/side light stalk is turned one or two clicks, the light just ahead of what was originally the ashtray comes on in the centre console.
project.r.racing
Postby project.r.racing » Sat Mar 08, 2014 5:13 pm
does a na8 even have a engine light?
i think it is just brake, oil and charge lights.
add door and airbag if the door is open or you have an airbag fitted.
booki89
Postby booki89 » Sat Mar 08, 2014 6:32 pm
That's what I was referring too! The binnacle. I also only get charge and handbrake. Just looks like there is a spot for two more lights to show up.
I don't think mine has airbags.
Good too know that light in the center console is meant to be there. Although unsure why...haha!
sailaholic
Postby sailaholic » Sat Mar 08, 2014 7:52 pm
No door light.
sailaholic
Postby sailaholic » Sat Mar 08, 2014 7:53 pm
I did find out what they all are at one point. Some of them aren't used in Aus models. Pretty sure no oil light either because of the gauge.
Postby 93_Clubman » Sun Mar 09, 2014 9:53 am
booki89 wrote:Good too know that light in the center console is meant to be there. Although unsure why...haha!
Probably to act as a marker for the opening of the ashtray (if still fitted).
sailaholic
Postby sailaholic » Sun Mar 16, 2014 8:53 am
Just a FYI or incase some else searches. The following is based on a 93/94 Aus delivered na8.
Light above fuel gauge = hardtop demister - fitted.
Headlight with arrow in taco = headlights moving - fitted
Hold light in taco- no idea guessing to do with a auto box.
Light below oil gauge is high beam - fitted
Below that is the "main section"
Top left - charge light - fitted
Top right - hand brake - fitted
Bottom left - check engine - not used
Bottom right - seatbelts - not used
Bottom left by itself is abs - not fitted
Bottom right by itself - washer (I assume level) - not fitted)
