195/50R15 tyres on 15x8 rims?
sleeptec
Re: 195/50R15 tyres on 15x8 rims?
Postby sleeptec » Tue Mar 04, 2014 10:29 am
Have rung around a couple tyre shops and none of them want to put 195s around an 8" wide rim.
sailaholic
Postby sailaholic » Tue Mar 04, 2014 9:45 pm
Seeing as a 215 is the smallest recommended by most manufacturers you can't really blame them can you?
CM sport
Postby CM sport » Fri Mar 07, 2014 8:12 pm
Get on it. Have had 195/50's on plenty of 8" rims. Also have never had a shop even question my intentions when asking what tires I wanted. I regularly drive the car hard also and have never had a problem on mine nor any of the other cars we have fitted them too. Even run Achilles 123 semis in a 195 and had no issues. The stretch is at an absolute minimum.
I see so many people saying this is dangerous blah blah blah but how many of those people have ever actually used one like that.....
Postby hks_kansei » Fri Mar 07, 2014 9:16 pm
CM sport wrote:I see so many people saying this is dangerous blah blah blah but how many of those people have ever actually used one like that.....
I have.
It's sh*t.
You end up with a stupidly rigid sidewall and less grip than the same tyre on a proper rim.
Then, I'm not even a fan of 195s on a 7 inch rim.
kazama
Postby kazama » Fri Mar 07, 2014 9:31 pm
radials are usually at their best (grip wise) when the wide of the carcass matches the width of the wheel
195 yokohama s drives have a section width of 7.8", potenza re-11s are 7.9". 8" wide wheels may be a touch too wide but its nothing to write home about. 195's are usually fastest on 7.5s.
sailaholic
Postby sailaholic » Fri Mar 07, 2014 10:34 pm
They are also illegal if that ever became an issue
kazama
Postby kazama » Fri Mar 07, 2014 11:49 pm
sailaholic wrote:They are also illegal if that ever became an issue
true
but so are basically all of our mods without an engineers cert
Ceptor
Postby Ceptor » Tue Mar 11, 2014 12:37 pm
I'm running 195 Achilles 123's on a 15x8, minimal stretch, cops a flogging and feels fine through corners, haven't had an issue
