How warm should an SE gearknob get?
- davekmoore
The alloy gearknob on my SE got up to body temp today on a 50k drive in mid-20 degree outside temps and dríven at no more than 100kmph and no more than 3,000 revs.
Is this normal?
Is this normal?
- Regie
- Vehicle: NC - V8
Re: How warm should an SE gearknob get?
I remember the voodoo knob on my NB used to get bloody hot after a decent drive.
hows your gear boots looking?
- StanTheMan
I would have taken that as a given. SE are sex on a stick.
sorry. back standard progarmming now
I used to have a metal gear knob on my car as well, and didn't like it - too hot in summer, too cold in winter...so I switched to a teflon Works Engineering knob available from MX5 Mania (shameless plug
- tescoking
I got a chrome gear knob and I had got burned once because of it.
- davekmoore
Sounds like mine is normal then. I need gloves in winter and it needs a glove in summer.
- Vehicle: NB8B - Turbo
Ive got a machined ss knob and it used to get to like 35-40 degrees on drives down to the coast. Replacing the shift boots made a big difference, I'd check this out.
Yes they do get hot in summer when the car's been sitting in the sun with the top down.
- 'tis a test of your worthiness to drive the car, much like the Shaolin monks who must brand their forearms on a scalding cauldron to prove that they have become a Shaolin Master!
davekmoore wrote:SE got up to temp today on a 50k drive
On the road again - congrats Dave!
How many have had the H pattern sticker come off their SE gearknob?
- davekmoore
93_Clubman wrote:davekmoore wrote:SE got up to temp today on a 50k drive
I have a machined Momo one on my NA that the previous owner bought at vast expense. I have put a piece of plastic tube over the shaft and then put the knob over that - it both gives a better fit and insulates it a bit. It still gets warm though.
Tim
Tim
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
My plastic NB8A gear knob was getting VERY hot, so I replaced the shift boots, problem solved. Those rubber things make a huge difference.
"Don't go crashing into Vulvas. *Volvos"
- davekmoore
Intact boots certainly reduce the noise and heat getting into the cabin but don't stop heat being transmitted into a metal gearknob from the lever.
I might try the sleeve mentioned in one of the posts. Any more details?
- davekmoore
davekmoore wrote:93_Clubman wrote:davekmoore wrote:SE got up to temp today on a 50k drive
Thanks, but still a lot of snagging to be done before it's a useable car again
