MX5 Just died. Wont Catch.
zc32s
Postby zc32s » Sun Mar 02, 2014 2:31 am
So Ive been driving my mx5 all day and its been fine. I started the car to drive home and everything was still fine. Drove the car for a minute and it lost all power as I changed to 3rd gear. I tried turning it back on and the car just cranks. :(
Does anyone know where I should start?
I have a feeling something happened to the fuel system.
I cant smell any fuel when I crank the car. The tank is still half full.
Anyone in the eastern suburbs of Melbourne able to give me a hand?
tescoking
Re: MX5 Just died. Wont Catch.
Postby tescoking » Sun Mar 02, 2014 2:34 am
any smoke or burning smell?
My 5
Postby Magpie » Sun Mar 02, 2014 6:11 am
What model car?
Sent from my iPad using Tapatalk
zc32s
Postby zc32s » Sun Mar 02, 2014 9:07 am
Sorry. I shouldve stated in my opening post. Its an NA8.
There's no smoke or burning smell. It just cranks and cranks.
Carnage
Postby Carnage » Sun Mar 02, 2014 9:31 am
Do you have spark?
Sent from my GT-I9300 using Tapatalk
zc32s
Postby zc32s » Sun Mar 02, 2014 10:03 am
Im going to check now whether it has spark or not. Had to roll the car up a hill back to my mates house. I've got very limited tools. I'll report back soon.
zc32s
Postby zc32s » Sun Mar 02, 2014 10:24 am
So my friend doesnt have any tools so I cant trouble shoot anything. Anyone in melbourne free and willing to give a hand?
emily_mx5
Postby emily_mx5 » Sun Mar 02, 2014 10:47 am
Try to rule out a couple of things, easiest is fuel pump.
In the engine bay there is a small diagnostics box passenger side wheel arch.
You can test the fuel pump by connecting a bridge wire from the TFP terminal to the GND terminal.
This directly powers the fuel pump, open the fuel filler to hear it easily, it should be a whine noise.
if no noise it indicated the pump is dead, or the connectors are too corroded to turn it on.
Also check air intake, as your symptoms sort of sound like a big air leak.
zc32s
Postby zc32s » Sun Mar 02, 2014 12:12 pm
So I pulled out the battery cable before. I just reconnected it to test the fuel pump.
The car no longer cranks, but this is possibly due to a drained battery since ive tried to start it so many times.
There is a high pitch noise coming from the fuel filter when I bridged the F/P and Ground. Im going to check the air filter box now. So where to next?
Bauer
Postby Bauer » Sun Mar 02, 2014 12:20 pm
Timing belt?
Did it sound like it was turning over fast when you were trying?
Thats my guess given that it lost power during a gear change. Take the oil cap off while you are turning it over to see if the cams are moving.
cheers
Stu
zc32s
Postby zc32s » Sun Mar 02, 2014 12:27 pm
I was thinking it is the timing belt as well.
I checked the cams earlier and it was turning when I was cranking the car.
Postby 93_Clubman » Mon Mar 03, 2014 10:03 am
Postby Mr Morlock » Mon Mar 03, 2014 11:12 am
you start by joining the RACV and take it from there- that is what the vast majority of people do.
zero00
Postby zero00 » Mon Mar 03, 2014 12:40 pm
Mr Morlock wrote:you start by joining the RACV and take it from there- that is what the vast majority of people do.
Agree MM - evil necessity
Roger D-SUNSHINE COAST
zc32s
Postby zc32s » Mon Mar 03, 2014 5:49 pm
LOL that's exactly what I did this morning.
Hopefully my car will be back on the road soon.
Users browsing this forum: No registered users and 63 guests
