Oil sump plug size
- Locutus
Re: Oil sump plug size
M14x1.5
Locutus wrote:M14x1.5
not being rude but are you sure?, as i have recieved a magnetic sump plug from uk and its not fitting, apparently same size (M14x1.5)
- Locutus
Yes - that's the spec of the plug that I'm using and it fits perfectly.
Have you measured your new plug to verify the thread and pitch are correct?
- Vehicle: Non MX-5
didn't the pitch and thread change pre and post 98?
My only listing for the engine drain plug is M14x1.5 and I sell drain plugs. It's not uncommon for the sump to be drilled and tapped to the next size e.g. m16x1.5 if it has been cross threaded in the past. Have you measured the plug that does fit?
- Learner Driver
Digging this question up from the archives as want to check the thread size on my 1990 MX5. Anyone confirm for sure please?
Users browsing this forum: No registered users and 71 guests
