Sounds like a wear and tear thing.
The thrust washe gets old and with years of wear/heat it allows more movement to the point that parts clip each other.
I'd think that replacing/upgrading the washer should do plenty.
And yeah, helical gears tend to try to force each other apart sideways, unlike straight cut which just tend to try and climb each other.
5 Speed Lada Nivas have a similar issue with 5th gear, the gear faces don't fully mesh (instead of being 100% face contact it's below 50% if I recall)
Under load the helical gears force each other apart a bit, and if the load is high enough they begin to only mesh on the ends of the teeth, where they then snap the teeth off and destroy 5th.
Granted, it's also worsened on that box since the oil level is below 5th, so 5th tends to also run pretty dry and unlubricated. (which is why you shoudl over-fill the box on a Niva and never engage 5th below 90kph)
So, the moral here is that if you want strength in a gearbox, maybe don't use the box from a Lada.
RB25 Gearbox Swap
Re: RB25 Gearbox Swap
- corners
- Vehicle: ND - Supercharged
I think its a lot to do with the additional power and torque as I don't imagine Nissan had the box designed to factor in a 50% increase in the factory output
corners wrote:I think its a lot to do with the additional power and torque as I don't imagine Nissan had the box designed to factor in a 50% increase in the factory output
Sorry, I thought you meant it was an issue on S15 boxes in general (stock or not)
I can see how putting a decent chunk more power and torque into a box might cause issues
- corners
hks_kansei wrote:corners wrote:I think its a lot to do with the additional power and torque as I don't imagine Nissan had the box designed to factor in a 50% increase in the factory output
Haha it only seems common on s15s when people wind the wick up more.
Its very rare for standard s15s to break.
Lol, it's vary rare for a standard S15 to exist at all these days.
- corners
Another common swap these days is Z33 to retain 6 speed but I don't know how hard of a job that would be in an mx5
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
I wonder if very solid engine mounts and a gearbox crossmember would help the 6 speed.
Would be good if there is an economical way to make a high horsepower MX5 be reliable.
