Gauge Wiring Advice
brendanstacey
Gauge Wiring Advice
Postby brendanstacey » Wed Feb 19, 2014 7:06 pm
Hi,
Im currently wiring two gauges, a MTX-L wideband sensor and a MTX-D water temp sensor and am looking for some confirmation on wiring.
Both need to be wired to a switched 12v source with a minimum fuse size of 3A and 2A for the AFR sensor and the water temp sensor respectivaly. I was thinking of using the cigarette lighter. What is the best way to hook both these wires up to the one wire?
For the ground, where is the best location relative to behind the tombstone that I can use (around 40-50cm of wire to play with i think)?
An lastly a headlight power wire for both the gauges. Again what is the best way to hook up two wires to an existing wire?
One last thing, I was thinking of just leaving/taping the water temp sensor inside the firewall untill I get an adaptor. This should be fine with the sensor powered up right?
Thanks for the advice/help
A.Chen89
Re: Gauge Wiring Advice
Postby A.Chen89 » Wed Feb 19, 2014 9:52 pm
Cig lighter has a 20 amp fuse on it, so that's fine.
I recommend using a crimped connection, there's a sleeve/butt connector you can get. Soldering would be fine.
Water temp sensor will be fine taped up. The probe is just a fancy resistor.
Watch some mighty car mods clips
sailaholic
Postby sailaholic » Wed Feb 19, 2014 10:16 pm
You don't want headlight power you want park / dash lights trigger to dim the gauges. For memory the stock radio wiring has a dining trigger wire. Pick that one up, if you screw it up your lights will still work.
brendanstacey
Postby brendanstacey » Wed Feb 19, 2014 10:45 pm
The manual says in caps. "Do not connect this wire to the headlight dimming wire. Connection to this rheostat type switch will cause the gauge to malfunctions".
So abit confused now.
Locutus
Postby Locutus » Wed Feb 19, 2014 11:06 pm
You can ground anywhere on the chassis, but make sure you make a good electrical connection. Easiest way is to crimp a ring terminal and bolt it down.
If you are using the analogue outputs on the gauges (with an aftermarket ECU perhaps) then you should share the ECU ground instead.
brendanstacey
Postby brendanstacey » Wed Feb 19, 2014 11:36 pm
Thanks, im using a serial output to my ECU so that should be all fine.
Looking at a wiring diagram - it seems the lighter has its own ground which shouldnt be too noisy. Ill have to see if I can reach it though tommorow.
Still unsure about the dimming though.
sailaholic
Postby sailaholic » Thu Feb 20, 2014 6:13 am
The stereo dimming wire isn't connected to the rheostat, it's just a straight on / off trigger wire.
Grab a multi meter and check if your not sure.
brendanstacey
Postby brendanstacey » Thu Feb 20, 2014 7:41 am
Ok, thanks for that.
I'll get to wiring it today and I'll see if I have any troubles.
Thanks everyone for the advice.
brendanstacey
Postby brendanstacey » Thu Feb 20, 2014 4:20 pm
Ok I'm having trouble running the wires from the gauges. It looks like the wires are confined to the ducting when I install the gauge. Does anyone know any tricks in order to wire around the ducting (and to the cig lighther/ground etc) or will I have to drill a hole in the ducting to run the wires through?
sailaholic
Postby sailaholic » Thu Feb 20, 2014 6:51 pm
Just use your radio power wire. Easier to get to.
brendanstacey
Postby brendanstacey » Thu Feb 20, 2014 7:56 pm
The manual suggests not to use the radio and ignition systems as sources. Why would that be?
A.Chen89
Postby A.Chen89 » Thu Feb 20, 2014 8:05 pm
High current /noise/potential ground loops. Look up the difference between sensor ground and a chassis ground/earth
brendanstacey
Postby brendanstacey » Thu Feb 20, 2014 8:20 pm
So the cig lighter should still be the way to go?
Users browsing this forum: No registered users and 84 guests
