Rear Lip + Mud Guards
Alfadog
Postby Alfadog » Sat Sep 01, 2007 2:32 pm
Hi guys,
Just wondering if anyone has any info about fitting the rear under-bumper lip whilst still keeping the mud guards in place?
I think I'll have to cut the rear lip to do it, but thought someone may have done it before and could share hints/tips!
Adam_NAclubman
Postby Adam_NAclubman » Mon Sep 03, 2007 4:21 am
If you run decent offset wheels it'll be bloody obvious to cops behind you that you've increased the track if the wheels are sitting an inch+ proud of the outer edge of the mudguard flappy things
Swizzel
Postby Swizzel » Fri Sep 07, 2007 12:36 am
Hey Alfadog,
I'm not sure about fitting, however I am wondering where you bought the rear lower lip from? I have been struggling to find one available. Any info would be great. Thanks
White '93, a few mods.
\"Every K over is a killer.......Maybe do some exercise then before you get hurt!!\"
Alfadog
Postby Alfadog » Fri Sep 07, 2007 9:19 am
Hey mate,
I bought it off a member here as he was parting out the good bits from his car before selling it!
green_comet
Car Detailing Guru
Postby green_comet » Fri Sep 07, 2007 12:54 pm
Alfadog,
You need to trim the rear lip, soo you can fit it without removing the mudguards. Do a search on miata.net, or clubroadster.net, you should find enough information on what needs to be done. :D
Ryan
nath
Postby nath » Fri Sep 07, 2007 2:08 pm
Maybe just take off the mudflaps? It'll look a lot tougher then.
Alfadog
Postby Alfadog » Fri Sep 07, 2007 7:06 pm
Ryan, yup, I did that and got the templates somebody used to do the same thing.
The car has had a respray thus I can't just take the mudguards off (they didn't take them off for the respray). I'm going to see if I can find a panel shop to see if anyone can fix it up for me... without respraying the whole panel.
Swizzel
Postby Swizzel » Thu Oct 04, 2007 12:45 am
Alfadog wrote: I did that and got the templates somebody used to do the same thing.
Alfa dog, if you have the template or any info on the trimming that needs to be done, I'd appreciate it is you could email it to me.
Wondering how the result worked out?
I have manages to find a rear lip from NZ which hopefully should land within a week and then I will get stuck into it ASAP
Thanks,
Samuel
Alfadog
Postby Alfadog » Thu Oct 04, 2007 7:23 pm
Hi Samuel,
Here is a link to the files I was given.
I did not try it out in the end. I decided I'll wait until I get a front lip and wheels, then get the areas under the rear mud flaps painted and fit the rear lip without modifying it.
Make sure you let us know how you go with yours though! I hope the template files help.
Fatty
Postby Fatty » Thu Oct 04, 2007 8:00 pm
where can i get this lip from? also i'd be interested to see photos of one on a car without the mudflaps.
Swizzel
Postby Swizzel » Fri Oct 05, 2007 8:24 am
Thanks Alfadog,
yeah I think I will have a go at modifying the mud guards, I'm going to get the rear lip and front lip painting when I get the hardtop done so I should look like a pretty clean job. Plus I don't mind the look and practicality of having the mud flaps. And if they do get butchered the guards are an easy thing to replace anyhow.
cheers again,
Sam
Swizzel
Postby Swizzel » Thu Oct 11, 2007 1:46 am
Hey guys,
I was wondering if anyone knows about installing the rear lip, it arrived today from NZ (www.mx5mart.co.nz) as a second hander. It looks pretty much in great condition, however, it didn't arrive with any clips or screws.
I haven't had a chance to get underneath the car as yet and check out the set up, the lip has a tab on it (no hole) that looks like it would probably get a screw or similar. I know when I installed the front lip that it had just a few clips and a couple of self tapping screws for the install.
Just looking for some insight if anyone knows until I get the chance check it out.
Also, what do you recommend I cut up the mudguards up with, just file it away gently or go a little for aggressive and use a cutter with a bit of power :)
Sam
Swizzel
Postby Swizzel » Sat Oct 13, 2007 1:27 pm
looks like I will be getting the dremel out onto the guards after all. I removed the guards today and I like the look of the car with the guards on a fair bit more.
Also if I was to keep the guards off, I reckon I will need to fill the holes and give them a paint anyway, to make it look clean. So I may as well chop up the guards.
Sam
aka_juffa
Re: Rear Lip + Mud Guards
Postby aka_juffa » Mon Feb 17, 2014 12:26 pm
Time to bring back an old thread :)
Anyone want to share their photos of a NA with the rear lower lip spoiler installed with and without the rear mud guards.
I have just bought a 2nd hand spoiler and trying to decide to delete or keep the mud guards.
J.
Users browsing this forum: No registered users and 34 guests
