What to do with old gearbox
Purfler
Postby Purfler » Mon Feb 10, 2014 1:09 pm
Having replaced the 5 speed gearbox in my NA6 with low km 5 speed I now have the old 'box hanging around. It has done 190,000km and has a bearing going. My inclination is to try to replace the bearing(s) mostly as a learning exercise for me. I have not been able to find an estimate of the cost of the bearings (I have not rung Mazda as I was not going to use genuine). Possibly this is another stupid idea of mine, as the replacement box with 50K kms was only $230 (plus seals).
Any thoughts?
Regards,
Tim
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
TTT
Re: What to do with old gearbox
Postby TTT » Mon Feb 10, 2014 2:49 pm
Postby hks_kansei » Mon Feb 10, 2014 2:54 pm
If you want to have a shot at rebuilding it go for it.
As for the bearing, rather than Mazda, you'd be better off removing the bearing and taking it in to a bearing place (CBC bearings or someone like them) and getting a new one to use.
my GF builds gearboxes and she says they aren't that difficult if you take your time. Go slow, don't force anything, LABEL EVERYTHING.
Pamex
Postby Pamex » Mon Feb 10, 2014 3:21 pm
They're great fun. Go for it. I'm just sad HKS won't let me redo my three speed whilst the engine is out. Do one thing at a time he said. *sniffs* :mrgreen:
You will definitely need to replace gaskets and seals if you open it up. I would recommend doing all bearings and check synchros
zossy1
Postby zossy1 » Mon Feb 10, 2014 4:17 pm
Find someone who will build you a straight cut gearset and go nuts :twisted:
Purfler
Postby Purfler » Mon Feb 10, 2014 7:54 pm
Thanks all for the comments :D
I have nothing to loose (and no-one I hate that much), so I will have a go. I was going to take the bearings to CBC to get a match - I read that suggestion on the web somewhere else. I took the low km one I put in the car apart after I bought it as I didn't believe the claim about it's kms. Getting the box apart to the point where I had the guts - to be technical - out in a unit was not that hard. I bought the special gasket stuff for re-assembly and it would be a shame to waste it. It wil be good practice for the gearbox from my Datsun 2000 Sports which has been standing around for 30 years :(
Thanks again,
Tim
Postby hks_kansei » Mon Feb 10, 2014 9:27 pm
