zossy1 wrote:I just sold a JDM VVT engine for $1,100. It had 34,000kms and I had bore scoped and done a cylinder leakage test so I knew the engine was a gooder. Buyer didn't want the loom but I would have thrown that in for a small sum.
BUT no ECU/immobiliser/key. That's the problem with a VVT swap if you're sticking with the OEM ECU and loom. You need it all (loom, ECU, immobiliser and key with nb8b ignition lock receiver) to make it work.
I've read that you can do it with non VVT loom and ecu and an aftermarket VVT controller. Is this wrong?
