NA8 gearbox shifting difficulties
Eeyore
Postby Eeyore » Sun Feb 02, 2014 9:34 pm
I'm after some general advice on the following. The standard 5-speed in the NA8 is becoming quite difficult to put in to gear in certain situations. It has occurred both after long drives and in car parks going from reverse to first among other occasions. The thrust bearing is a little noisy so I'm wondering if that is the culprit. Could it be something worn in the shifter linkages or some other well known issue with these boxes as they get on in ages.
Kurt
1971 1300 Estate Deluxe
1973 1300 Wagon
1979 RX7
maroubra
Re: NA8 gearbox shifting difficulties
Postby maroubra » Sun Feb 02, 2014 9:54 pm
Hopefully not asking the obvious, have you changed the oil in the turret?
MrRevhead
Postby MrRevhead » Sun Feb 02, 2014 9:57 pm
Besides the turret oil and linkage/shift boot replacement, throw some Nulon smooth shift with some GL4 based oil (even the cheapy VMX 80) in the box and see if there's any difference.
If not, save up/start searching for a replacement.
Postby 93_Clubman » Tue Feb 04, 2014 9:07 am
If you haven't already, it's worth checking the clutch slave cylinder isn't weeping into its rubber boot.
Eeyore
Postby Eeyore » Tue Feb 04, 2014 7:06 pm
Thanks guys no I haven't changed the oil in the gearbox although this may have been done at time or roadworthy which was less than a year ago. An additive might be a good idea actually. Yes I have checked the slave cylinder it doesn't appear to be leaking and is functioning as normal.
Kurt
1973 1300 Wagon
1979 RX7
maroubra
Postby maroubra » Wed Feb 05, 2014 8:14 pm
Hi Kurt
Maybe have a look at these YouTube clips
They explain the turret oil service, and the other lockout mechanisms in the gearbox.
http://m.youtube.com/watch?v=biBjZhmkxZc
http://m.youtube.com/watch?v=ANRaTCqL4DE
Hope this helps
James
sprinterfiend
Postby sprinterfiend » Sun Feb 09, 2014 2:16 pm
When I bought my MX5 it had a full factory service history.
Apparently that didn't seem to include flushing the clutch fluid.
My car had the same symptoms as yours. I flushed the (possibly 150k old) gravy like substance that used to be hydraulic fluid and it shifts properly now.
10 dollars for a bottle of dot4.
cheap fix.
Users browsing this forum: No registered users and 96 guests
