Hi All, just wanted to contribute my experience for future driver's with a similar problem. I did end up searching this forum as well as miata.net but there were several answers, so i ended up on a little goose chase.
Symptoms
-difficulty in engaging reverse gear
-no difficulty engaging forward gears
Check
-check for clutch fluid wetness near clutch master reservoir and hose leading from it
Problem
-leaking clutch fluid hose coming from the clutch master reservoir
Solution
-replace the leaking clutch fluid hose
What I did end up doing was changing the transmission fluid which resulted in a slicker shift, but no improvement engaging reverse. Also, unfortunately clutch fluid got leaked onto my firewall which is not so good for the paint. Live and learn!
2000 NB8A hard to get into reverse gear[Solved]
- Kenstaki
Users browsing this forum: Bing [Bot] and 3 guests
