Wheel alignment specs for NC
CoachOz
Postby CoachOz » Tue Jan 28, 2014 10:56 pm
Can anyone suggest some good wheel alignment specs for country roads
2020 ND 2 GT
2000 NB Heritage
[imgImageHeritage 2 by Peter Rodgers, on Flickr[/img]
Charlie Brown
Re: Wheel alignment specs for NC
Postby Charlie Brown » Wed Jan 29, 2014 8:41 am
As you are now back into stock suspension and I assume want stability on the road with some good feel through the corners use these:
Front
1.0 degree negative camber
6 degrees 36 minutes castor
2mm total toe in
Rear
1.0 degrees negative camber
3.0mm total toe in
CoachOz
Postby CoachOz » Thu Jan 30, 2014 10:20 am
Current settings are shown below - is the difference compared to your suggestions significant?
Front Left side
37 minutes negative camber
6 degrees 18 minutes castor
Front Right side
18 minutes negative camber
6 degrees 20 minutes castor
Front - 2.8 mm total toe in (1.4 mm per side)
Rear Left side
53 minutes negative camber
Rear Right side
42 minutes negative camber
Rear - 3.2 mm total toe in (1.6 mm per side)
2020 ND 2 GT
2000 NB Heritage
Charlie Brown
Postby Charlie Brown » Thu Jan 30, 2014 4:08 pm
Responded via email. :wink:
Users browsing this forum: Bing [Bot] and 5 guests
