Wheel alignment specs for NC
- CoachOz
Can anyone suggest some good wheel alignment specs for country roads
- Charlie Brown
Re: Wheel alignment specs for NC
As you are now back into stock suspension and I assume want stability on the road with some good feel through the corners use these:
Front
1.0 degree negative camber
6 degrees 36 minutes castor
2mm total toe in
Rear
1.0 degrees negative camber
3.0mm total toe in
Front
2mm total toe in
Rear
3.0mm total toe in
- CoachOz
Current settings are shown below - is the difference compared to your suggestions significant?
Front Left side
37 minutes negative camber
6 degrees 18 minutes castor
Front Right side
18 minutes negative camber
6 degrees 20 minutes castor
Front - 2.8 mm total toe in (1.4 mm per side)
Rear Left side
53 minutes negative camber
Rear Right side
42 minutes negative camber
Rear - 3.2 mm total toe in (1.6 mm per side)
Front Left side
Front Right side
Rear Left side
Rear Right side
- Charlie Brown
Responded via email.
Users browsing this forum: No registered users and 365 guests
