Camera mounts for motorsport
Re: Camera mounts for motorsport
Looks good PT
- oztrackdays
http://www.ebay.com.au/itm/Precision-ma ... a82&_uhb=1
Probably overkill but I found the Official One would flex and is a bit cheap and flimsy.
Yup that looks the goods.
- PT
That looks like it would be sturdy enough but the arm isn't long enough for what I want to do unfortunately.
I bought one of these and it arrived today.
http://www.ebay.com.au/itm/Motorcycle-H ... d32&_uhb=1
It was more wobbly than anything else I've used and definitely a waste of money.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
- MattR
On my phone so difficult to see what you have, but if not already look at the Ram branded mounts. Not cheap but very good. I used to have a huge selection of arms and mounts for full size handicams fir my work and have mounted the cameras to cars, inside and out, trains, boats, hovercraft and helicopters with no shaking of the images at high speeds.
Google ram mounts or johnny appleseed GPS for pricing info on the whole range.
I also use this stuff, it is very strong and allows you to put a camera almost any where on a car to get some great angle shots
http://www.stickypod.com/examples/dash-cam/
Video from the setup above.
- PT
I've ordered one of these: http://tinyurl.com/jvsnnc4
And one of these to make the arm longer to clear the seat: http://tinyurl.com/l7k2x7j
Should have them tomorrow. Will report back once I've tested them.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Don't forget the longer the arm the more the vibration is transmitted to the camera.
- PT
I've got my ram mounts fitted up. Holy crap are they solid. This is the view I've achieved but I haven't had a chance to go for a drive yet.
Hopefully it want shake as much, it is certainly the most solid attachment I've tried though.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
To reduce shake try and angle it up and not just point it straight out, however a GOPRO more than likely weights less than a Contour+ which I found shakes with the same mount you have.
http://www.rennenmetal.com/proddetail.asp?prod=1008
mounted to full roll bar and can take a video camera and no questions asked by CAMS scruts.
No shake and can be fitted to any part of your roll cage or bar.
I got one in the porker as well as scooter.
You guys seen these?
http://www.ebay.com.au/itm/Sunvisor-mou ... 887&_uhb=1
No idea if it fits GoPro (I don't have one), just came across them one day..
- PT
Yeah, OMGPHAM (site sponsor) sells them.
You could fit a gopro but you'd need the 1/4 thread to go pro adapter.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
- Vehicle: NB Roadster
Okibi wrote:I've tried 2 locations with my gopro rollbar mount...Bottom bar I think is the better off the 2...
Yeah, plus when you roll the car, the camera stays attached and you get awesome footage for later. Top bar, bye bye camera. Priorities!
