Weird noise, not sure if clutch or gearbox
sunlightsilver
Postby sunlightsilver » Wed Jan 22, 2014 9:45 am
Hi guys,
I've got a strange noise that started maybe a week ago.
Basically it only happens in 1st, 2nd (sometimes) and reverse which leads me to believe gearbox, not clutch.
The common factor is that this noise occurs at low speed. If I hammer it in 1st and change to 2nd going a reasonable speed this noise wont happen, its only if I'm crawling in traffic etc in 2nd. The noise is a screeching sound that happens as I release the clutch and start accelerating, it doesn't last a very long time - it will go away after i pick up even a small amount of speed. It just occurs as the clutch engages and I accelerate for maybe 1-2seconds. I can draw out the noise longer if I take off more gradually.
Has anyone experienced this before? My car is an nb8b, not sure if i should be concerned with this noise.
Craig
Re: Weird noise, not sure if clutch or gearbox
Postby Craig » Wed Jan 22, 2014 9:51 am
Clutch bearing, mine did the same thing! :cry:
sunlightsilver
Postby sunlightsilver » Wed Jan 22, 2014 10:16 am
Found a video showing the noise, this is exactly what mine does.
http://s139.photobucket.com/user/aclemo ... 9.mp4.html
Pretty sure its still the OEM clutch, car has 152xxx k's on it. Probably just old and due for replacement?
Postby manga_blue » Wed Jan 22, 2014 10:31 am
sunlightsilver wrote:Pretty sure its still the OEM clutch, car has 152xxx k's on it. Probably just old and due for replacement?
At least you've got a bit of time now, rather than being stuck on the side of a mountain somewhere. I'd do clutch, release bearing and rear main oil seal together.
davekmoore
Postby davekmoore » Wed Jan 22, 2014 12:28 pm
Clutch release bearing. Do what manga_blue says.
sunlightsilver
Postby sunlightsilver » Wed Jan 22, 2014 12:32 pm
Yeah that's what I was thinking.
I guess an exedy clutch kit would suit fine?
JBT
Postby JBT » Wed Jan 22, 2014 3:39 pm
Sounds more like the flywheel spigot bearing to me. In any case, you'll have to take off the gearbox as per clutch replacement and replace it along with the clutch and release bearing.
sunlightsilver
Postby sunlightsilver » Thu Jan 23, 2014 10:20 am
Picked up an exedy clutch kit, the rear main oil seal and pilot bearing for $250 incl postage - will probably be doing DIY with my brother who's a mechanic. Hoping to learn a bit in the process :)
monty11ez
Postby monty11ez » Tue Jan 28, 2014 2:16 pm
It shouldn't e too bad. I had mine go out on me not too long ago. It was fun. lol
Users browsing this forum: No registered users and 107 guests
