MattR wrote:Just one thing to say.......
Told ya so!!!!!!!!!![]()
Magpie wrote:plohl wrote:1157kg is pretty heavy![]()
Ouch, somebody had to add it up, however I never will post the car weight without the driverplohl wrote:1With the squirming under braking, have you looked at your shock settings? Might be getting too much weight transfer to the front.
At the moment there is more rebound in the rear so that the weight transfer from front to back is slowed once braking is almost complete. My logic is so that the front does not unload too quick.
Maybe softer spring rates on the front could be tested?
Magpie wrote:Could you sand/soda blast instead of grinding? I may as well learn from your mistakes if I have to go down that path...
sailaholic wrote:Personally I'd have wanted to do a full season of competitive Motorsport and loved it before converting a road car I'd put that much effort into (albeit for track type use) to track only. Tapatalk
