2007 NC Front Wheel Bearings
Agro67
Postby Agro67 » Mon Jan 13, 2014 6:54 pm
Hi All,
Hoping to get some advice from the forum.
My mechanic has advised me that front wheel bearings need replacing.
Are these seperate bearings on in a Hub kit?.
Any recommendations on where to buy these from in or around Brisbane would be a great help.
Cheers - Agro
Re: 2007 NC Front Wheel Bearings
Postby Regie » Tue Jan 14, 2014 7:53 am
they are a hub kit
if you can source some RX8 hubs, they bolt straight up and are much stronger
Charlie Brown
Postby Charlie Brown » Tue Jan 14, 2014 8:25 am
As Regie said, get the RX-8 hub but it must be the later model RX-8 after 2009 for the ABS sensor connection to match.
The hub is a full sealed unit so you can't change the bearings and from personal experience, DON'T get an after market hub. I had ABS and fitment problems with the two I tried.
Read all about it in this post: viewtopic.php?f=79&t=60644
Agro67
Postby Agro67 » Tue Jan 14, 2014 8:49 am
Thanks to Charlie Brown & Regie for the advice
Users browsing this forum: Google [Bot] and 249 guests
