MX5 project with 2GR-FE Aurion Engine
Xauterus
Re: MX5 project with 2GR-FE Aurion Engine
Postby Xauterus » Fri Jan 10, 2014 10:31 pm
Yeah on the rear I will have some wider outer bands made for the 3 piece wheels so they will end up around 12 to 13"
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Wed Jan 15, 2014 9:37 am
seems like a lot of tyre!
good luck with the build.
oztrackdays
Too Much power for the Chassis
Postby oztrackdays » Wed Jan 15, 2014 9:51 pm
The Turbo crew used to get 200 - 220 rwkw out of the NB platform but the whole car starts to self destruct,
you will need half shafts axles, wheel bearings, diff, gearbox etc .... I run 15x8 wheels on racecar and had to roll guards
and they still hit, 18 inch wheels will not actually work on track loads even if you flare guards etc ...
Rear suspension travel is an issue as well.
Your car is likely to be call it 975 kg max and 300 rwkw would be 3.25 Kw per kilowatt
Look at some production benchmarks and you will get an idea of what is needed engineering wise.
Lotus Exige S with weight of 930 kg / 155 rwkw = 6 kg per kw
458 Italia 1500 kg / 336 rwkw = 4.4 Kg (THIS IS BIG FUN tracked one in italy)
The McLaren F1 1140 kg / 376 rwkw = 3.0 (only marginally better than yours.)
You are basically building a Sports sedan from an unsuitable base sports car,
it will cost you way more to bring everything up to spec than you want to spend.
If you love you TOYBOATA engines I would research this
http://www.woodsport.org/joomla/index.p ... onversions
there are two already going in NSW and it's a shitload less trouble than being a Pioneer in an MX5.
Xauterus
Postby Xauterus » Thu Jan 16, 2014 10:02 am
The MX5 body will end up being just a vessel for this project. I am intending to put the body onto a spaceframe chassis similar to a sports sedan. The rear suspension will basically be Nissan S15 uprights and arms. The subframe will be replaced by a tube frame. Gktech make some alloy uprights to replace the stock ones and moly arms. I am already using a skyline diff and axles that will handle my project power output.
I expect this car to be quite a handful. I wanted to build this car in the spirit of Australian specials form the 1950s. A car put together from a whole lot of different cars and ingenuity. I really like the fabrication side of a project like this. I intend for this to be a learning car, I hope that I can build more cars after this. Maybe the next one will be far more sensible.
Postby manga_blue » Thu Jan 16, 2014 10:08 am
Good luck with it all. Is the MX5 wheelbase going to be long enough for all this?
Xauterus
Postby Xauterus » Thu Jan 16, 2014 8:19 pm
The Ariel Atom has a very similar ratio wheelbase to track.
Postby manga_blue » Thu Jan 16, 2014 9:07 pm
Maybe so, I'm thinking short wheelbase, wide track AND shedloads of power. It's going to be a fun car.
sailaholic
Postby sailaholic » Fri Aug 22, 2014 1:28 pm
Friend had a sw20 with the aurion v6. Had dramas with the gearbox but I think it was the constant swapping of ends that tipped the balance into selling it.
plohl
Postby plohl » Fri Aug 22, 2014 2:01 pm
^ plus he can never keep a car or bike for more then a few months.
plohl
deviant
Postby deviant » Fri Aug 22, 2014 2:29 pm
Magic Lamp wrote:...Power is expected to be well over 400hp...
Naturally aspirated 400BHP...spooooooooge
Return to “MX5 Motor Sport”
