PPM Rods Pistons any good? is 8.5 ratio good for a 15 PSI
Re: PPM Rods Pistons any good? is 8.5 ratio good for a 15 PS
Postby Magpie » Thu Jan 09, 2014 8:18 am
Sounds like Jason has a busy start to 2014. Good luck with the build and you are in good hands at MX5 Plus. I like dropping in just to see Danny's build!
tomli123001
Postby tomli123001 » Thu Jan 09, 2014 11:21 am
Magpie wrote:Sounds like Jason has a busy start to 2014. Good luck with the build and you are in good hands at MX5 Plus. I like dropping in just to see Danny's build!
Thanks Magpie. Actually this is my 2nd built engine when I go ahead. The 1st one built by MX5 plus was in that white car, which rolled off the hill :(
Saw your car there a lot. I like the unique color scheme you have on it.
NA6-Rolled off Mt Nebo
NB SE-Sold for investment property deposit, then crashed by the buyer months later
Now Black NB SP #31.
Postby Magpie » Thu Jan 09, 2014 12:38 pm
tomli123001 wrote: [Actually this is my 2nd built engine when I go ahead. The 1st one built by MX5 plus was in that white car, which rolled off the hill :(
Aaaah I remember seeing that there just after it arrived on the back of a trailer. My concern was for the occupant and was told driver was OK!
Thanks for the comment on my car, yes it has spent a lot of time there. It is due to go back there as well to have some more work done, however it is not critical so it will be when Jason is free. This could change depending on my track plans for 2014 :)
The rumour is that the Automotive Plus track car will be gaining a turbo this year, so it would appear that, at least for MX5 Plus, 2014 is to be the year of the turbo (Dann will be happy). If only somebody else would do a natural aspirated build :)
Good luck with the build and hopefully Mt Glorious will be kinder to you this time :)
