Just went to raise the electric windows in my NA and they decided not to operate, both sides. Could this be a fuse and where is the fusebox located?
Had been operating fine 10 minutes earlier
Thanks
NA ELECTRIC WINDOWS
- zero00
NA ELECTRIC WINDOWS
Roger D-SUNSHINE COAST
Re: NA ELECTRIC WINDOWS
The fuse is above the drivers kick panel, if you have an import look for this text.
(パワーウィンド)
30A
(パワーウィンド)
30A
- zero00
jimmy_vee wrote:The fuse is above the drivers kick panel, if you have an import look for this text.
(パワーウィンド)
30A
Thanks Jimmy - not sure what that means but will look there
Nice work Jimmy
- zero00
Thanks guys, cruised down to 'Pirates' place after coffee this morning, he found the fuse box near the kick panel, my neck prevents getting in at that angle but a 'remove and re-insert' of the fuses under the bonnet and all is working well again
Thanks again to all - appreciated!!
