Okibi wrote:Sounds better, been meaning to do a similar one with varex open/closed.
Now that would be interesting!
Have you fitted the BEGi intake yet?
Before & after on both counts would be great.....
AntHarmer wrote:I had the aerial issue so just hooked it up to a switch so I can put the aerial up only when I am listening to the radio.
In terms of the screen not working, you need to ground the wire meant to connect to your handbrake wire to watch the screen whilst moving - I'm not advocating doing this for obvious reasons but that is what you need to do
Nevyn72 wrote:Very nice!... Much more modern that the OEM unit.
Did you install this yourself?
If so, did you have much difficulty removing the factory unit? (I've read that this can be a bit tricky)
Okibi wrote:And replace those silver accents on the aircon vents?![]()
http://www.pixelculture.com/SE_28thDec2013_02.jpg
Lokiel wrote:Now that you've replaced the head unit, consider replacing the HVAC fascia with a stock black NB one or, as I did, "repaint" the existing one with black vinyl dye (see http://mx5cartalk.com/forum/viewtopic.php?f=55&t=38070&hilit=saga).
I thought that the silver plastic fascia looked cheap once I installed my Pioneer head unit, black looks much better and matches the head unit better.
Before:
Much better, especially with the chrome trim rings, they match the head unit's trim.
After:
Vinyl Dye is great, it seeps into the plastic and still looks good several years later. Paint is not so good, it tends to chip.
