How often should clutch fluid be replaced?
NMX516
Postby NMX516 » Tue Dec 24, 2013 3:25 pm
The owners manual for the NB8B just lists that the clutch fluid should just be "Inspected" at every service, but never replaced...
I would have thought it should be done at least every couple of years as it can absorb moisture over time, or at least change it at the same intervals as the diff and gearbox oils.
Thoughts??
project.r.racing
Re: How often should clutch fluid be replaced?
Postby project.r.racing » Tue Dec 24, 2013 3:37 pm
40K - as per user manual.
NMX516
Postby NMX516 » Tue Dec 24, 2013 3:45 pm
Yep that's a fair interval, but as I mentioned, the owners manual doesn't list any interval at all for replacement.
I just had the 100k service done and all other fluids were changed, but not the clutch fluid despite it looking old and black...
Postby hks_kansei » Tue Dec 24, 2013 4:08 pm
The proper tool is a machine that measures it and tells you the moisture content.
It's cheaper to just change the fluid every so often though, a bottle of Castrol Super Response is like $12, and that bottle will likely do 5 clutch fluid changes.
tescoking
Postby tescoking » Tue Dec 24, 2013 6:27 pm
Change when the colour turned dark
My 5
Postby manga_blue » Tue Dec 24, 2013 6:31 pm
Normally every 2 years for both clutch and brake fluids on any car. It's time dependent, not mileage dependent. The fluids absorb moisture over time. You could change them less often if you lived out the back of Bourke and more often at Bondi. Change the brake fluid every 6-12 months if you're tracking it.
If you waited until the colour went dark then that could indicate either that you have corrosion in the cylinders or degradation of the seals and it's too late.
JBT
Postby JBT » Tue Dec 24, 2013 9:37 pm
I get the clutch and brakes flushed at the same time. It's a common reservoir on most cars these days.
NMX516
Postby NMX516 » Wed Dec 25, 2013 10:45 am
Thanks for the replies guys. So as I thought, no good reason not to have changed the clutch fluid...
Postby Regie » Thu Dec 26, 2013 8:35 am
yep every year for me, when I do the brake fluid also
