NB8B hot day idling problems
- Neilus
So at the tail end of a 3 hour drive today my NB8B started coughing and either refusing to rev or doing it very erratically. It felt almost exactly like the heat had gotten to my CAS but both the CAS and main relay were replaced a few months ago after the last time the heat made my car stop. I hit the CAS and green relay with a fair amount of electronic freezer spray when i got home and it didn't seem to help. Are the fuel or pump the likely culprits or are there other known heat related nb8b issues?
Re: NB8B hot day idling problems
If it's not either of the EGI relay or CAS you replaced a few months ago, then I'd replace the other CAS before the fuel pump. One CAS is the cam position sensor & other CAS is the crank position sensor.
ie CAS/crank position sensor:
http://www.ebay.com.au/itm/Genuine-Mazd ... 1938wt_985
as opposed to CAS/cam position sensor:
http://www.ebay.com.au/itm/Genuine-Mazd ... 20d29f213a
- tescoking
Maybe the IAC sensor is getting old. I had this before, after service and drove 4.5 hrs for roadtrip and the car just like yours.
- Neilus
It's a strange issue this time around. It was well hot today and I'd been on a long drive so I thought it was another failing part made worse by heat but the car's actually sputtered a second or so each time I've started it cold the last 2 days.
Will a failing Crank Position Sensor start working again if I cool it with freezer spray so I can diagnose it?
- tescoking
Neilus wrote:It's a strange issue this time around. It was well hot today and I'd been on a long drive so I thought it was another failing part made worse by heat but the car's actually sputtered a second or so each time I've started it cold the last 2 days.
Don't try to freeze it, they are plastic and it could crack. Under normal temperature the computer should be able to read the sensor.
if you can get the car to do it again with a qualified person at hand you might actually be able to diagnose the problem rather than just replace things. Also some of the links with so called OEM parts are not the real deal. Check the Mazda workshop manual for diagnosis -93 has probably got a link- its very good written by Engineers with full trouble shooting and how to do. Many things of course we cannot do without the equipment. Incidentally just because the day was hot it does not necessarily mean there was any connection to the problem.
Neilus wrote:Will a failing Crank Position Sensor start working again if I cool it with freezer spray so I can diagnose it?
Wouldn't rely on this method as a definitive way to identify a faulty crank PS or cam PS.
Diagnostics on page two of following:
viewtopic.php?f=29&t=59479
- Neilus
Beautiful, thanks. I'll get stuck in.
Both my NA's had this problem once, was dying coilpacks in both cases.
Users browsing this forum: No registered users and 77 guests
