5x Hazard Light Flashes.... Error code?
Rasputin
Vehicle: NB8A - Turbo
Postby Rasputin » Fri Dec 20, 2013 10:39 am
As title states.
Also have a red car with a key inside it flashing above my temp gauge.
Two long strobes then 4 short ones.
Car no longer running factory Ecu.
Thanks guys!
Re: 5x Hazard Light Flashes.... Error code?
Postby hks_kansei » Fri Dec 20, 2013 10:47 am
Did it start just after the ECU change?
I would hazard a guess that the new ECU doesn't use the immobiliser chip in the key, and the light is whatever remains of the immobiliser system saying that it thinks it's been hotwired or something (perhaps it's expecting a signal from the ECU?)
No idea how the system works, but normally a car with a key logo is a symbol for immobiliser/alarm/central locking
greenMachine
Postby greenMachine » Fri Dec 20, 2013 6:16 pm
NB8A? Try the alternator - mine did that before I found some dodgy diodes in the control module. I was running a Haltech E8 at the time, IIRC.
:mrgreen:
Rasputin
Postby Rasputin » Fri Dec 20, 2013 7:09 pm
Well the 5x Hazard light flicker happened occasionally even with the stock ECU in. Sometimes it happens twice in a perfect series, making it ten flickers. It flickers at about twice the pace than if you were to press the hazard light button.
The Car with the key light only happened after I changed the ECU out to Adaptronic.
Yeah, it's an NB8A.
Greenmachine, what do you mean - Check my Alternator?
Thanks!
Dan.
greenMachine
Postby greenMachine » Fri Dec 20, 2013 7:59 pm
Rasputin wrote:Greenmachine, what do you mean - Check my Alternator?
The NB8A alternator has a control module inside it - the voltage regulator. This has diodes, which failed in my case. Replacing the alternator, or just the module if the rest is still good, is the fix for this problem.
See if you can borrow an alternator - make sure it is the right one - and see if the problem goes away. Obviously, it needs to be an alternator you know is working properly.
:mrgreen:
EDIT: AFAIK, this has nothing to do with running an aftermarket ECU, at least mine was unrelated. I replaced the alternator, and all was good.
