Hey guys!
So I spent the last hour modifying my actuator and bracket to fit, bent the actuator rod and it's all honky dory!
The only piece left for the puzzle is the small ring/circlip that sits on top of the actuator rod to lock it onto the flapper door.
What is the exact name of this part, so that I may order it.
Thanks guys!
Dan.
Wastegate actuator rod circlip?
- Vehicle: NB8A - Turbo
Re: Wastegate actuator rod circlip?
Its an 'E' clip, available from repco etc.
Thanks Dann. Low and behold I'll walk into repco asking for said part and get a bunch of weird looks. The staff at the local repco are a bunch of space cadets.
Dan.
Dan.
You can buy a mixed packet at Repco, located on the tree stands, where all the nuts and bolts hang.
Both you and Emily are correct.
- taminga16
NitroDann wrote:Both you and Emily are correct.
REPCO needs more Emily's.
OK, but REPCO needs more Emily's.
I assumed Greg knew when he posted that
Agreed nonetheless, repco needs more emilies.
- taminga16
I can hear SCA screaming for Emily's.
Greg.
Come to think of it, there is a Burson's in Bendigo that could do with two!
Greg.
As Emily said, there they were!
Thanks again, lifesaver.
Car is finally going to chu-chu tomorrow! Looking very forward.
Thanks.
Dan.
Thanks.
Dan.
