What brake pads for NC MX5 for street and some track?
DavidM
Postby DavidM » Mon Dec 09, 2013 8:58 pm
Hi guys,
What brake pads would you recommend for an NC that's dríven hard ... and will see the odd track day?
- #1 priority is that they don't fade.
- #2 priority is no noise/squealing as the car spends 99% of the time on the road.
ps. Also is it enough to replace just the front pads ... or are the rears too soft/weak for the track?
Thanks.
Regards,
David
JBT
Re: What brake pads for NC MX5 for street and some track?
Postby JBT » Mon Dec 09, 2013 9:00 pm
I'm using Remsa at the moment. A bit dusty but very good stoppers. Very affordable too from Brakes Direct.
You only need to replace the pads that are worn. No need to do the rears if they are OK.
Charlie Brown
Postby Charlie Brown » Tue Dec 10, 2013 2:41 pm
Is your NC modified or standard?
If your NC has no engine modifications then your stock OEM pads will be fine.
Once you start heading up the pad range into performance pads then dust and noise increases.
Unless you have slotted rotors stay away from Hawk HPS as they WILL fade after a lap or two. Otherwise they are quite and don’t dust and these are the pads I’m using at the moment for the road.
Hawk HP+ dust but are a road/track pad.
Hawk Blues are a track pad and can be noisy and dust heavily.
EBC Green are just a street pad.
EBC Red are a performance street pad , they dust and the manufacturer says they ARE NOT a track pad. Experience shows they are correct as the pad material rips away from the backing plate at the track
EBC Yellow can be used at the track and on the road but dust a lot.
Carbotech XP12 is for the serious racer and they don’t like slotted rotors. I swap my rotors and street pads for these on track days. They are dusty and VERY noisy at slow speed. They operate to 1200 degrees C. I noted on the weekend that they said the V8 Supercar pads only go the 1000C.
If your NC is stock you could use the Carbotech 1521 or if you want a little more the XP8.
But if you’re stock at the moment, the OEM pad does a fine job until you need to replace them when they are $$$ compared to aftermarket pads.
DavidM
Postby DavidM » Tue Dec 10, 2013 6:55 pm
Thanks for the info guys. The MX5 is stock with the exception of coil-overs. Though the stock pads seem to give up pretty quickly when driving 'spiritedly' on a twisty road. So looking for something little bit more resilient ... but as mentioned before - also quiet.
I have not heard of Carbotech or Remsa ... but will look them up.
ps. How much (roughly) are you looking it for a set of pads?
Thanks.
Regards,
David
mazmad
Postby mazmad » Tue Dec 10, 2013 9:02 pm
I have used Carbotech XP10 and 12, with slotted rotors, with good performance. They do need to be bedded in and if you have used another pad on the disc beforehand you will need to work to bed them in.
little decks
Postby little decks » Tue Dec 10, 2013 9:24 pm
I've used brand new XP12s on a stock NC around SMP south circuit, was really a bit of an experiment as we thought they might be too aggressive... took about a lap and a half of ferocious braking for them to come on but holy crap when they come on its a phenomenal feeling, but because of the heat range of them you really need to be very aggressive in your braking and using a semi-slick, I've only ever used the XP10s on an earlier model but they still perform well enough to send any unwelcome passenger through the front windscreen.
little decks
Postby little decks » Tue Dec 10, 2013 9:33 pm
Although this is all just track stuff I should add, there are AX6s which are a road/track suitable pad.
Deckspeed Racing
Postby Deckspeed Racing » Tue Dec 10, 2013 9:56 pm
Hi
Deckspeed Racing are the Australian Distributor for Carbotech.
We stock
1521 Low Dust
AX6 road and track
XP10 Track and normal racers without ABS
XP12 Experienced racers or anyone with ABS
We carry pads for all MX5s
www.deckspeedracing.com.au
JBT
Postby JBT » Tue Dec 10, 2013 10:07 pm
DavidM wrote:Thanks for the info guys. The MX5 is stock with the exception of coil-overs. Though the stock pads seem to give up pretty quickly when driving 'spiritedly' on a twisty road. So looking for something little bit more resilient ... but as mentioned before - also quiet.
Thanks.
Remsa front pads -$108 in January 2013
OEM front pads - $176 in April 2011
The Remsas have done 6 track days this year and should be good for at least one more. Then I'll get a new set for NatMeet. They are dead quiet as opposed to the OEM which howled when cold after a while. Much more dusty than OEM though.
DavidM
Postby DavidM » Wed Dec 11, 2013 6:44 pm
Thanks for all the info guys ... much appreciated. Will read up on all of these.
Anyone used the AX6? If so how are they with the occasional track day?
Regards,
David
JBT
Postby JBT » Wed Dec 11, 2013 7:38 pm
No, not just track stuff. My car is used about 90% normal use and the rest on track days. I will be getting Remsa pads to replace the current ones when they are worn to limits.
little decks
Postby little decks » Wed Dec 11, 2013 7:42 pm
DavidM wrote:Thanks for all the info guys ... much appreciated. Will read up on all of these.
They are the next step up from the Carbotech 1521 pad which are a high performance road pad, the AX6 is better for track stuff but every now and then some people report some minor squealing from them.
DavidM
Postby DavidM » Wed Dec 11, 2013 11:33 pm
Any noise / squealing from the Remsas JBT?
Regards,
David
JBT
Postby JBT » Thu Dec 12, 2013 6:04 am
No noises. They have a sort of rubberised backing on the pad plates to stop metallic noise (the OEM replacement pads howled when cold) and the pad material doesn't squeal either.
craigj
Postby craigj » Fri Dec 13, 2013 2:42 pm
EBC Yellow Stuff on the front and Red Stuff on the back work great road and track. Hawk Track Day pads are brilliant for the track but sqeal like buggery on the road.
Craig
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 194 guests
