Ticking noise from rear left wheel
elliptoid
Postby elliptoid » Mon Dec 09, 2013 11:09 pm
Hi all,
I have a ticking noise coming from my rear left wheel. It is definitely coming from the wheel area, as the frequency changes with speed.
I've checked the tire, it isn't a stone hidden somewhere.
Is there a common cause(s) of this noise by any chance?
Thanks heaps in advance.
1990 NA6. Now with central locking
david_syd_au
Re: Ticking noise from rear left wheel
Postby david_syd_au » Tue Dec 10, 2013 7:00 am
It could be a wheel bearing.
When a front wheel bearing went on my car it made a ticking noise, but in that case it was also accompanied by a rumbling under load, ie turning left at speed, loading the front right wheel bearing.
2011 NC LE "Black Beauty" (ours) | 2006 NC race car "Shazza" (his) | 1998 JDM NB race car "OMG" (hers) | NC Trailer
JBT
Postby JBT » Tue Dec 10, 2013 7:17 am
Check for a worn, stuck or loose brake pad.
Postby 93_Clubman » Tue Dec 10, 2013 11:32 am
elliptoid wrote:Is there a common cause(s) of this noise by any chance?
viewtopic.php?f=30&t=57795
chrons_rotary
Postby chrons_rotary » Tue Dec 10, 2013 3:51 pm
elliptoid wrote:Hi all,
Had this exact problem, same noise whether acceleration or decelerating, turned out to be a wheel bearing.
Easy to replace if you have a press and bearing puller kit, but hard if you dont.
Ken.
