vincevince wrote:Thanks again for the help speedfreak
No worries, glad to have been some sort of assistance
Glad you found the problem!
vincevince wrote:7. Couldn't check for spark as I didn't have a helper
10. Fiddled with the underhood fuse box and tucked it back into it's original spot (wiring was tucked and thus fuse box isn't on original mounting)
11. Voila! . Cranks, fires, brum bruuum.
12. Whilst it was running, I thought that maybe it's the fuse box and the wiring being loose. - Moved the fuse box around by twisting it a bit, pushing it down, pinching the wires under it, pulled it up, etc.
Initially, when I put it up against the corner of the firewall and fender, the engine would begin to stall and splutter. Eventually it died. Tried to crank, but no fire.
vincevince wrote:Anyone know how long a whole loom swap would take and cost for loom itself?
Users browsing this forum: No registered users and 102 guests
