James's SE
Re: James's SE
Sure. Look, roll bars should be fully legal- your life your choice, I mean, you take your chances when you cross the street, and it does look cool.
Re: James's SE
Dan has hit the nail on the head.
I sold mine because:
-I was over the look
-It is not cams or FIA approved
-From an engineering point of view, the selected materials, bends, and connections are not really correct for the application or the loads that are to be expected in a crash or roll.
Padding on Jap rollcages does not do much either. Sure it makes it more comfortable to lean on the bar or when you accidentally bump it. Try punching the bar and it will feel just as solid.
You need sfi rated padding. Even with this it is dangerous in road conditions as it is designed to absorb impact with a helmet on.
Btw welding the front legs and the main hoop together means that you will not be physically able to remove the cage from the car. I tried doing this with the cage as one piece. Enjoy the cage as is and when you get bored of it (or defected ) you can sell it on later.
After my cage I settled with a MX5+ Tall Boy and will get some bolt in door bars.
Just giving you some of the things I've learnt from my studies and past experience.
Re: James's SE
deffinetly want to get at least a few things done before the first track day of 2014! brainstorming a few things...
-braided brake lines
-brake fluid
-good pads
-rollcage
-finish up splitter( attach it to chassi finally)
should be pretty good bang for buck ^^
let me know all your thourghts!
-brake fluid
-good pads
-rollcage
Re: James's SE
just a little update, bourght some guage faces today. getting made in us as we speak i dont know if anyone else finds these as exciting as i do haha but ye. staring at the same old OEM dash for like 3 hours a day, i need a change!! here are a few pics of what they will look like installed.
and for those of you who follow Danny george ( who i am a huge fan of), this is his personal design for his new NB mx5. if anyone doesnt know him they should go check him out! he is a pro drifter. and i know alot of people here probs wont respect drifting for what it is but if u get into it its really interesting, the only difference between a drift car and a time attack car is pretty much the suspention and drive style. let me know what u think!
Re: James's SE
I don't think you took into account that the SE/MSM needles are red - might make reading the tacho a bit hard?
You might want to consider getting a cluster with white needles and use those.
Re: James's SE
Lokiel wrote:I don't think you took into account that the SE/MSM needles are red - might make reading the tacho a bit hard?
Good point, but look at them!! I have a sudden case of
- timk
Re: James's SE
Are those the exact ones? They look like they would only suit the Jap clusters with the resting position of the needle at 6 o'clock.
Re: James's SE
yea he said what position did i want, i guess ill figure it out later how to change it later, wanted something different to stock ( position) and yea ill just change the needles, also got 2 custom changes that arnt in those pics but ill take pics of them when its all installed .
Re: James's SE
SO! been really busy with work and shiz but i finally installed guage faces ^^ took about an hour and a half all up including test running to test speed/revs ect. here are alot of pics xP
^ this is with out the faces at all, had to cut a plastic to let the light spread.
^ these were practice marks for the needle stopper. had like 5 practice "places" just to be sure i would screw the real deal :p
there we have it :p looks amazing imo and exactly what i wanted!! gives me a change to look at was a pretty simple install, just had to be very carefull and not even touch the guage faces, as it will ruin them. wore gloves that came with the guages which was awsome. tell me what u think!!!
cheers
James
cheers
James
- Regie
- Vehicle: NC - V8
Re: James's SE
wow that looks awesome!
Re: James's SE
Love the 6 o'clock "0" dial position but think you should replace the tacho needle with a white one.
Also, BLUEWAFFLEGARAGE? What am I missing?
Re: James's SE
Lokiel wrote:Love the 6 o'clock "0" dial position but think you should replace the tacho needle with a white one.
people red the garage they go to ( JDMGARAGE is probs the most commen) and i do most of my work on a mates driveway :p and we call him bluewoffle so thourght ide take the piss out of all the "jdmgarage" guys and rep this haha. its hard to explain :p
Re: James's SE
The gauges look great James.
- Vehicle: ND - RF
Re: James's SE
Love that fuel gauge!
- fastfreddygassit
- Waitin' for a mate
Re: James's SE
Oh wow!
The gauges look sensational!
Top stuff
Top stuff
Users browsing this forum: No registered users and 171 guests
