Steering wheel not straight after bump?
sailaholic
Re: Steering wheel not straight after bump?
Postby sailaholic » Wed Dec 04, 2013 10:00 pm
NitroDann wrote:On a commodore no, on an MX5 with poly bushes and an aggressive alignment you would be surprised.
Can't see how that is possible. A flat evenly worn tire should be physically identical to the one that came off.
Postby NitroDann » Wed Dec 04, 2013 10:20 pm
If I said that there is no such thing as a perfectly flat evenly worn tyre, and an aggressive wheel alignment with front toe out is a LOT different to one with no toe or toe in in terms of being affected by this, would you agree that it can be an issue regardless?
project.r.racing
Postby project.r.racing » Thu Dec 05, 2013 7:08 am
dont drive a commo, cannot comment. i only switch wheels and tyres on cars that have poly bushes and aggressive alignments. as these track related cars need more tyre switches.
NitroDann wrote:If I said that there is no such thing as a perfectly flat evenly worn tyre, and an aggressive wheel alignment with front toe out is a LOT different to one with no toe or toe in in terms of being affected by this, would you agree that it can be an issue regardless?
evenly worn tyres switched with evenly worn tyres wont change alignment.
unevenly worn tyres switched with equally unevenly worn tyres wont change alignment.
evenly worn tyres switched with unevenly worn tyres will change alignment.
Postby NitroDann » Thu Dec 05, 2013 9:29 am
Thats not true and I wont debate it further. Poly bushes, and an aggressive alignment will change the steering wheel position and whether the car pulls or not very slightly almost no matter what if the wheels or tyres are changed.
project.r.racing
Postby project.r.racing » Thu Dec 05, 2013 11:55 am
NitroDann wrote:Thats not true and I wont debate it further. Poly bushes, and an aggressive alignment will change the steering wheel position and whether the car pulls or not very slightly almost no matter what if the wheels or tyres are changed.
i dont believe the debate was about poly bushes and aggressive alignement changing the steering wheel position.
i'm sure it was about wheels and tyres being swapped changes/doesn't change alignment.
dave2221
Postby dave2221 » Thu Dec 05, 2013 12:02 pm
Have you tried reversing over the same bump? to fix the problem
StuwieP
Postby StuwieP » Thu Dec 05, 2013 6:00 pm
^thanks for that. I had a laugh. :D
My NA6/SE build
Engine #1 RIP 04/07/2020
Users browsing this forum: No registered users and 216 guests
