Andrew's '93 NA6 - KL V6 swap
Re: Andrew's '93 NA6 - KL V6 swap
Postby fastfreddygassit » Mon Nov 25, 2013 12:36 am
Hey Andrew
I'm the dude that had a chat with you in Gundagai today :mrgreen:
The engine swap (especially the plenum) look amazing in the flesh!
Well done :BROADY:
Beelzeboss
Postby Beelzeboss » Tue Nov 26, 2013 11:07 pm
fastfreddygassit wrote:Hey Andrew
Well done :BROADY:
Cheers mate! Was such a surprise to meet anyone from the forum in South Gundagai of all places :)
The MX-5 now has the KL 2.5L engine and made it to and from Wagga Wagga without breaking down (much) :D
Since the MX is now working so well I've been concentrating on getting my S13 Silvia working properly without so much turbo lag.
http://forums.mightycarmods.com/showthread.php?21523-Andrew-s-90-S13-Silvia
Andrew
NA-6 2.5 KL V6
http://barberprecision.com.au/
sailaholic
Postby sailaholic » Wed Nov 27, 2013 7:39 am
Haha. Sucker for punishment. 5.7 I assume not the 6.0.
Postby Jeo » Wed Nov 27, 2013 5:46 pm
More things need LS's.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Wed Nov 27, 2013 6:30 pm
sailaholic wrote:Haha. Sucker for punishment. 5.7 I assume not the 6.0.
yep its an ls1 from an ss.
zorst, throttle body, intake and tune are surely good for 400hp.
Beelzeboss
Postby Beelzeboss » Sun Jan 05, 2014 10:06 pm
:D 5.7 from a 2002 VY SS!
Jeo wrote:More things need LS's.
I agree, such a great engine.
16bit wrote:zorst, throttle body, intake and tune are surely good for 400hp.
and with a cam on top of that more like 400hp at the wheels :D
The Silvia is driving around now, I just need to fix up the exhaust, fix a few small leaks and... weld up a crack in the cylinder head :( In the rollover the exhaust manifold was ripped from the head and it looks like it's made a really small crack between the water jacket and the outside of the head. As far as I can tell it's not cracked into the combustion chamber or oil passages so that's something.
Anyway, I've been driving the MX-5 every day and it's working brilliantly. Still has a small oil leak at one of the rocker gaskets and needs new plugs, I'm going to fix both at the same time since they each need the intake manifold to be removed.
I just spent 5 1/2 hours cleaning up the garage and parked the two beasts in there for a photo shoot :D
It's like car heaven :D
Andrew
NA-6 2.5 KL V6
Postby orx626 » Sun Jan 05, 2014 10:59 pm
Love it! :beer:
Beelzeboss
Postby Beelzeboss » Thu Feb 13, 2014 3:10 pm
Hehe, thanks Danny :)
I took a couple of quick gopro vids on the way to the shops today with the windows up, it captures the intake a bit better than the last :D
Andrew
NA-6 2.5 KL V6
Postby bruce » Thu Feb 13, 2014 5:01 pm
Nice work BB! You've got the best of both worlds - a small fast car to zoom around in, and a grunt-meister when you feel the need.
Beelzeboss
Postby Beelzeboss » Sun Feb 23, 2014 12:52 am
bruce wrote:Nice work BB! You've got the best of both worlds - a small fast car to zoom around in, and a grunt-meister when you feel the need.
Thanks mate. Unfortunately I can't afford to keep both registered so once the Silvia is engineered I'll be cancelling the rego on the MX-5 :(
In the mean time I've just been enjoying the car, it's so much fun now that it runs well and doesn't leak oil :D Also the Silvia is going for undefecting and unregistered vehicle permit early next week. Then it's just emissions test, weighbridge, noise test and engineer inspection :D
Andrew
NA-6 2.5 KL V6
cwto24
Postby cwto24 » Sun Feb 23, 2014 2:18 pm
No :(
It's going to be goodbye to the MX-5?
Sad days...
Regie wrote:spending my money again Trevor :D
Beelzeboss
Postby Beelzeboss » Sun Feb 23, 2014 2:32 pm
Yeah, into the garage long term until I've finished my degree and have time to supercharge and engineer it :(... unless someone makes me a decent offer in the next couple of weeks.
Andrew
NA-6 2.5 KL V6
Vilko
Postby Vilko » Fri Feb 28, 2014 5:15 pm
Beelzeboss wrote:Yeah, into the garage long term until I've finished my degree and have time to supercharge and engineer it :(... unless someone makes me a decent offer in the next couple of weeks.
Just giving you a heads up I don't think you will pass emissions with that airbox on the s13. A friend of mine was failed because he was running an aluminium airbox, switched it to plastic and breezed through. That was for an EPA test, then he used it to get his engineers certificate.
Beelzeboss
Postby Beelzeboss » Fri Feb 28, 2014 11:55 pm
Vilko wrote:Just giving you a heads up I don't think you will pass emissions with that airbox on the s13. A friend of mine was failed because he was running an aluminium airbox, switched it to plastic and breezed through. That was for an EPA test, then he used it to get his engineers certificate.
Thanks mate but both my engineer and blue slip guy think an aluminium airbox will be fine. There's absolutely no reason why it wouldn't be allowed, I'd be interested to hear the reasons for rejecting an aluminium airbox. I'm sure I could find some stock cars which had aluminium airboxes.
Andrew
NA-6 2.5 KL V6
bigmaxy
Postby bigmaxy » Mon Mar 03, 2014 9:38 am
I don't see what material the airbox is made out of affecting the emissions test in NSW. From my understanding it is a simple pass or fail based on what comes out of your exhaust pipe following the IM240 procedure.
That's for the emissions part anyway.
Although that now has me thinking. Who checks things like having a catch can vented to atmosphere?
