Does this item exist?
Re: Does this item exist?
Postby hks_kansei » Sun Nov 24, 2013 9:18 am
Magpie wrote:If the metal is too thin do you think it is wise to use this location as an anchor point for something that could save your life?.
it's a suspension brace, not a rollbar or seatbelts, or something like that.
mitch_f1
Postby mitch_f1 » Sun Nov 24, 2013 9:51 am
Okay, I think I need to clarify this further. I purchased a later model rear subframe so that I could use a Beatrush PPF brace which I picked up on the cheap. The subframe that I purchased came with the 6 point rear brace. I was thinking it would be a good idea to install it, because you know, I had it, so why not. I am looking for a simple solution; I don't want to turn the car into swiss cheese just so I can add a brace. I know I could cut holes and put nuts in place, but I only wanted to drill the one hole and use a bolt (which I thought would exist, but apparently it does not) to secure it. It's become apparent that this project goes into the too hard basket for now, until I decide to start cutting up the body.
For reference, it is this brace:
Mounting to this location:
Like this:
Postby Magpie » Sun Nov 24, 2013 11:09 am
Thanks for the clarifications.
Postby NitroDann » Sun Nov 24, 2013 11:24 am
The solution is 2 rivnuts a side or 1 weld nut.
