EOI: Dodgy Day Round 3
Queensland Events
Moderators: timk, Andrew, miata, AJ
CaptainNate
Re: EOI: Dodgy Day Round 3
Postby CaptainNate » Fri Oct 25, 2013 8:26 am
These are probably them haha, the brand on them is D1 from Japan I believe. They were cheap so im keeping the stock latch for extra security. :)
Postby Magpie » Fri Oct 25, 2013 9:21 am
I probably have the templates at home and happy to lend them. Here is the link to my install http://mx5cartalk.com/forum/viewtopic.php?p=720665#p720665.
Get the pins in first where you want them, make sure that they hit the bonnet when you got to close them. Open the bonnet and put some chalk on the top of the pins, close the bonnet. When you open the bonnet drill the right size hole where the chalk was transfered onto the bonnet. It should not be that hard to make a template.
I also used this on my aerocatch as the bonnet is fibreglass http://miataroadster.com/password_jdm/password_jdm_aerocatch_mounting_plates/pwbamuniblk/i-249137.aspx and this comes with a solid template. I note that the new aerocatches come complete with fixing plates, this is a good move.
CaptainNate
Postby CaptainNate » Fri Oct 25, 2013 4:34 pm
Ahh the chalk idea is brilliant! That was one of the steps that I was having trouble with figuring out how to do.
The other step I'm having trouble with planning is getting the bolts on the underside of the hood, is the only way cutting a hole under the hood?
Postby Magpie » Fri Oct 25, 2013 5:22 pm
If you take out the rubber bumps stops that are already there you can put the hood pin bolts in there. I had to cut some length off mine because it hit some of the air con stuff, but you trim them down last (if at all). If you have a look at the first few photos in my thread you can see where I mounted the pins. Good luck :)
CaptainNate
Postby CaptainNate » Fri Oct 25, 2013 6:55 pm
Oops! I worded that in a rush and it was terrible haha. I meant how to get the 6 nuts on that screw onto the end of the bolts that hold on the actual clasp. My bad. :-(
Sent from my GT-I9505 using Tapatalk 2
zero00
Postby zero00 » Fri Oct 25, 2013 7:22 pm
I have no idea what that thing in the photo is Captain Nate and I'm stuffed if I know what a
dremel is either BUT, I DO know what an aglet is!! :roll:
Roger D-SUNSHINE COAST
Postby Magpie » Fri Oct 25, 2013 8:40 pm
Because you cut both sides of the bonnet and the screws go in easy. You may need to use the Dremel http://www.dremel.com/en-au/Pages/default.aspx or die grinder to make the cut out on the inside a bit bigger to tighten the nuts. I will see if I have some photos of the inside of the bonnet.
CaptainNate
Postby CaptainNate » Fri Oct 25, 2013 8:57 pm
Ahhh sick. Yeah, I was worried about cutting the inside as well because I didn't know what it would do to structural integrity, but everything is cleared up! If you've got pics that'd be awesome :)
I don't know what an aglet is, but I do know what a fox says!
ljs18
Postby ljs18 » Tue Nov 05, 2013 5:45 pm
Has to be the 16th as I have been volunteered to work on the 23rd. Just have to move some stuff to get cars in. Looking forward to it.
ljs18
Postby ljs18 » Mon Nov 11, 2013 2:52 pm
Flying MX5. Hope to have the gearbox out by Thursday night, change the rear main, transmission input and output seal to be ready for Saturday installation. 8)
D.A.M
Postby D.A.M » Thu Nov 14, 2013 9:25 pm
Im keen to come help out and meet etc :-) pm with details :-)
White 1993 NA6
viewtopic.php?f=57&t=57652
Lakeside: 1:09
Postby Magpie » Sat Nov 23, 2013 7:11 pm
How did this go?
ljs18
Postby ljs18 » Mon Nov 25, 2013 3:07 pm
Magpie wrote:How did this go?
Went alright. Gear box in on the red car and springs and shockies replaced on the blue car. Will be tinkering on the red car this Saturday morning, so if anyone wants to pop in pm me for address.
ljs18
Postby ljs18 » Fri Jan 17, 2014 1:44 pm
Bit of suspension work happening this Saturday. Bushes on a NB. Pop in if you're bored.
Dan-mx5
Postby Dan-mx5 » Tue Aug 19, 2014 6:02 pm
Its been a while! I'm in!
Return to “Queensland”
