can anyone help me out in adelaide??
Re: can anyone help me out in adelaide??
Postby 93_Clubman » Fri Nov 15, 2013 12:20 pm
How did you go borrowing an NA6 ECU? In case you haven't been able to borrow one & are not aware, you can buy a second hand NA6 ECU for under $50 on this forum. I know it would be better to borrow one, but if not possible then there are cheap ones out there. And they are occasionally a problem in NA6s & NA8s, so def worth considering as a cause. Sometimes a visual inspection of the ECU printed circuit board will reveal a problem as the board or earth post can show signs of blackening or discolouration, often a brown colour, from leaking capacitors.
thehillsarecalling
Postby thehillsarecalling » Mon Nov 18, 2013 6:01 pm
Hey mate. If you're still stick, send me a pm. I'm in adel and have a stock na6 ECU you can try, as well as a aftermarket ECU connected to a stock loom that we can use for diagnostic purposes.
I'm free after 6pm weeknights. If you're up north I might be tempted to drive around and have a looksy
Daily: '91 Malibu - NB8B conversion, 6sp, Teins, Whitelines
Terribly Missed: '02 Black SP (#55)
Plus about 12 others over the years..
