Dash lights not working
sweep77
Postby sweep77 » Thu Jan 03, 2008 9:35 pm
i'm sure i've checked all the fuses and seem to be fine. everything works except the dash lights aren't coming on. any ideas?
JBT
Postby JBT » Thu Jan 03, 2008 10:29 pm
Which model? Check the dimmer rheostat.
sweep77
Postby sweep77 » Thu Jan 03, 2008 10:57 pm
95. dimmer reostat? is that behind the dimmer switch?
JBT
Postby JBT » Thu Jan 03, 2008 11:25 pm
It's the dash lights dimmer thumbwheel thingy.
SuperMazdaKart
Postby SuperMazdaKart » Fri Jan 04, 2008 12:39 am
hrmm, headlights are on too?
TieNN89
Postby TieNN89 » Fri Jan 04, 2008 12:43 am
are you tail lights working?
i'm not sure with the mx5 but i remember when my 121 dash lights went out my tail light didn't turn on either
result blown tail light fuse
sweep77
Postby sweep77 » Fri Jan 04, 2008 7:26 am
yeah checked the dimmer but makes no diff. all the other lights seem fine. headlights work, just the dash lights stopped working. are they part of another circuit?
JBT
Postby JBT » Fri Jan 04, 2008 8:21 am
It looks like power comes to the light cluster through the \"tail\" fuse. If the heater controls and ash tray lights work, then you may have a dislodged or broken wire to the light cluster.
Please let us all know what you find.
sweep77
Postby sweep77 » Sat Jan 05, 2008 7:31 am
thanks. i put a cd player in and i think i've earthed it to the wrong part so it keeps blowing that fuse. i'll have a look tonight.
sweep77
Postby sweep77 » Sun Jan 06, 2008 10:32 am
All fixed. theres a red/black wire that goes to the standard tape deck which i thought was a negative which i had hooked the cd player earth up to. removed it and earthed somewhere else and works all good now. Thanks for that wiring diagram!
JBT
Postby JBT » Sun Jan 06, 2008 11:43 am
Glad you got it sorted. :)
dinknjim
Re: Dash lights not working
Postby dinknjim » Sun Nov 10, 2013 8:18 pm
Sorry to grave dig here guys.....
I've put a new h/u in recently too and lost my dash/ac lights...
What did u end up doing with the red/black wire that goes to the stock tape deck?
TieNN89
Postby TieNN89 » Sun Nov 10, 2013 9:26 pm
dinknjim wrote:Sorry to grave dig here guys.....
What head unit did you fit?
The Red/Black wire should be the dimmer wire on the NB8A which you don't really need to hook up but if you don't hook it up to your headunit (if it has that wire to hook up) then when you turn on your lights the head unit won't dim
I'm not sure why you've lost your dash/ac light thought unless it shorted out on something and blew a fuse
dinknjim
Postby dinknjim » Mon Nov 11, 2013 1:36 pm
The h/u I used is an alpine 117E, couple of years old now but still nice.
The wiring diag that I was working off had 2 wires as the interior lights, the red/black and a grey/red wire. i'll have to check the fuses today.
still have tail lights tho, so not too sure which fuse to check... looks like theyt are all on the list.
dinknjim
Postby dinknjim » Mon Nov 11, 2013 2:49 pm
dinknjim wrote:The h/u I used is an alpine 117E, couple of years old now but still nice.
Fixed :) red/blk goes to h/u. while the grey/blk wire need to be earthed
Users browsing this forum: No registered users and 239 guests
