Exhaust System
thelaughingman
Exhaust System
Postby thelaughingman » Sat Nov 09, 2013 6:27 pm
Hello Guys,
I'm trying to find some more info on this Exhaust that I've purchased from REV9.
its a 2.25" cat back Trust-power system. I've Googled and gone on the trust website and have not been able to find any info on it.
any help would be appreciated
link: http://rev9autosport.com/na/trust-mx-exhaust.html
Re: Exhaust System
Postby NitroDann » Sat Nov 09, 2013 6:43 pm
What did you want to know? I can tell you most of the important stuff by looking at it.
thelaughingman
Re: Exhaust System
Postby thelaughingman » Sat Nov 09, 2013 6:52 pm
Well full specs - gains over factory etc..
Re: Exhaust System
Postby NitroDann » Sat Nov 09, 2013 7:09 pm
Gains over factory..2-3hp on it's own.
Its aluminised steel piping with 304 stainless muffler and tip, the hotdog is also mild steel aluminised.
It has a 3" tip and a straight through muffler and of course all hotdogs are straight through.
thelaughingman
Re: Exhaust System
Postby thelaughingman » Sat Nov 09, 2013 7:13 pm
Thanks for that,
How much would be a reasonable gain to expect with 4-1 headers and a hiflow cat?
would 10-15 be about right?
Re: Exhaust System
Postby NitroDann » Sat Nov 09, 2013 7:18 pm
8-10 at a guess, depending on design, -more with an ecu and tune- you want to do the timing advance also if it;s going on an NA6.
thelaughingman
Re: Exhaust System
Postby thelaughingman » Sat Nov 09, 2013 9:00 pm
It is on a NA16, i've not done the timing adjustment yet. I plan to do that after i install the exhaust and do the Air intake properly, i know im never going to see big power but any improvement is better than none :)
project.r.racing
Re: Exhaust System
Postby project.r.racing » Sun Nov 10, 2013 10:34 am
NitroDann wrote:is also mild steel aluminised.
what is that?
NitroDann wrote:8-10 at a guess
that be very hopeful that high. Maybe and a giving dyno with light wheels.
mxfive95
Re: Exhaust System
Postby mxfive95 » Mon Nov 11, 2013 11:13 am
You can achieve 10-15rwkw and 10nm, if you get some decent cams. Look up warren Heath proformance on Facebook. He does a decent set of cams for under $500.
The bumper sticker on my porsche
"My other car is an mx5"
