Last Thursday I changed the battery on the MX-5 and now the radio doesn't work. It is displaying ERR. What can I do?
Mark Mansell. B.Eng.(mech).
MARTEZ ENGINEERING. www.martezengineering.com.au
ABN 20430704557.
ph 96059562.
m 0406043953.
radio shows "ERR" after changing battery
- Hellmun
- Vehicle: NB8B - Turbo
Re: radio shows "ERR" after changing battery
Most likely it just needs the pin code input. Do you have the original car handbook? Usually the pin code is on a business card in that on most cars I've owned. Not entirely sure on the mx5.
This also belongs in the electrical forum.
- Tezzax5
If it has the original radio then the pin will be the last four digits on the chassis number.
You only get three go's to type it in correctly.
Happy to flick you a pic from the manual if you don't have yours?
Cheers tez
Cheers tez
Tezzax5 wrote:If it has the original radio then the pin will be the last four digits on the chassis number.
Cheers tez
Not sure if it is the original radio, but I'm only the third owner. I'm about to try your last four digits of chassis number and see what happens. Thanks for your help.
ABN 20430704557.
ph 96059562.
m 0406043953.
- Caffeine
There is some sort of special button sequence that will unlock a locked radio. Had the dealer do it for me once after a service.
A bit like an MX5 konami code
Thanks everyone for your respective inputs. Today we plugged in a diagnostic disputer and tried everything from America to England and everything in between. All to no avail. I'm spewing about this. It's my car, my radio. Why should I have to pay a bunch of car sellers to get the code which is rightfully my property? It's called ownership. They say the code is there to protect the owner from losing the radio by theft. Well it might as well have been stolen as I have no radio anyway. Totally pissed, Marko.
- Caffeine
Tried this?
When displaying "err":
press 6>>
press AM
press Auto M
press ^
- - - - is displayed
enter the code 1414
press and hold Auto M & 6>>
Users browsing this forum: No registered users and 191 guests
