Alignment
dmad_dood
Alignment
Postby dmad_dood » Mon Oct 21, 2013 7:34 pm
Iv'e just gotta rave! I got my car's alignment done on the weekend and far out what a difference its actually funny how much better the car is just for the alignment. From what i understand more castor was dialed in and a fraction of camber, about -0.6˚car turns in 10 times better holds in the corner and is much more forgiving and overall balance has been improved 10 fold aswell. car is a dd so i didn't go overboard but im Very Happy!
Cant wait to get my good tyres on and unleash the beast!!!! :P :P
Jono.
Red NA8..
Trackphotos
Re: Alignment
Postby Trackphotos » Tue Oct 22, 2013 12:13 am
dmad_dood wrote:Iv'e just gotta rave! I got my car's alignment done on the weekend and far out what a difference its actually funny how much better the car is just for the alignment. From what i understand more castor was dialed in and a fraction of camber, about -0.6˚car turns in 10 times better holds in the corner and is much more forgiving and overall balance has been improved 10 fold aswell. car is a dd so i didn't go overboard but im Very Happy!
Jono.
I had my craptastic Yokohama A.Drives with chunks missing from the shoulder replaced this morning. 3 nights ago I went out and using my phone/GPS pair, had a quick run around some roundabouts to see what lateral G's I was able to get on cold, crap tyres. I had spikes of up to 1.3 G's, usually maintain 0.7 or so through entire roundabouts. Tonight I ran the same route again, but on brand new Federal 595 RSRs, also cold. Maintain 1-1.1 G's through roundabouts, spiking up around 2 G's at some points. Tomorrow, I'm having an alignment done. If it doesn't rain, I'll be doing the same again and seeing the difference :)
M1474
Vehicle: ND - Turbo
Re: Alignment
Postby M1474 » Tue Oct 22, 2013 12:37 am
Good feeling isn't it dood.
People go years without realising the potential of their vehicle.
It's the cheapest and most effective modification you can make to a car, I'm amazed at how bad so called "professionals" can do it.
GHETTOCET
dmad_dood
Re: Alignment
Postby dmad_dood » Tue Oct 22, 2013 5:57 am
I had my craptastic Yokohama A.Drives with chunks missing from the shoulder replaced this morning. 3 nights ago I went out and using my phone/GPS pair, had a quick run around some roundabouts to see what lateral G's I was able to get on cold, crap tyres. I had spikes of up to 1.3 G's, usually maintain 0.7 or so through entire roundabouts. Tonight I ran the same route again, but on brand new Federal 595 RSRs, also cold. Maintain 1-1.1 G's through roundabouts, spiking up around 2 G's at some points. Tomorrow, I'm having an alignment done. If it doesn't rain, I'll be doing the same again and seeing the difference :)[/quote]
What app are you using for that :) that would of been great to no of as a before and after. My tyres are also shockers, there probably at least 10 years old and im sure they were once made from rubber, now they have turned into wood.
Very excited for you to get the alignment :P
Jono
Red NA8..
Trackphotos
Re: Alignment
Postby Trackphotos » Tue Oct 22, 2013 10:28 am
dmad_dood wrote:What app are you using for that :) that would of been great to no of as a before and after. My tyres are also shockers, there probably at least 10 years old and im sure they were once made from rubber, now they have turned into wood.
Jono
Had it done this morning, won't have time to test properly til tonight but it already feels more pointy on turn in. The app I use is called Racechrono. It's a free app, but you really need to use an external bluetooth GPS with it for it to be any good. Phone GPS only updates once per second, the Qstarz 818xt GPS I use is 10 times. Forward/rearward G's are calculated by acceleration/deceleration, lateral G's are calculated using the phones internal accelerometer. The map overlay is a bit skewed most of the time, google maps don't fit perfectly to real coordinates. Changing the number of satellites it's connected to makes it move a little bit, which is why the line on these two maps are both showing me cutting the kerb.
Here's the comparison for one of the roundabouts, old tyres on elft side, new tyres on right. Was focusing on corner speed here rather than G's.
dmad_dood
Re: Alignment
Postby dmad_dood » Tue Oct 22, 2013 8:39 pm
That is a very cool app, ill have to give it a try when i get a chance. Cant wait to get my good rubber on - got a near new set of re002's on my rims from my old car in the garage but don't like how they look on the 5 so i'm trying to source a nice set of rims to put them on.
I might just cave as the bolt straight on :P
Red NA8..
Re: Alignment
Postby Jeo » Tue Oct 22, 2013 9:48 pm
So that's an 80km/h speed limit on the round-about yeah?
Trackphotos
Re: Alignment
Postby Trackphotos » Tue Oct 22, 2013 11:48 pm
Jeo wrote:So that's an 80km/h speed limit on the round-about yeah?
Certainly is :) 80kmh each way, Valley Way in Mt Cotton. Tried it again tonight once the tyres were a bit warmer, maintains 65-70kmh through the whole thing. Very impressed.
Tommo
Re: Alignment
Postby Tommo » Wed Oct 23, 2013 1:28 am
Managed 1.9G at QR on the 595RS-R, which are many many heat cycles old/daily drive tyres.
Pretty impressive!
maroubra
Re: Alignment
Postby maroubra » Tue Nov 26, 2013 8:17 pm
Do you know if that app is available for iPhone?
Trackphotos
Re: Alignment
Postby Trackphotos » Fri Nov 29, 2013 1:22 am
maroubra wrote:Do you know if that app is available for iPhone?
Android and Symbian only, but Harry's Lap Timer on iOS is the one everyone else uses. Has a great reputation, don't think it's free though.
maroubra
Re: Alignment
Postby maroubra » Fri Nov 29, 2013 12:41 pm
Thanks i was thinking I was going a bit mad when I couldnt find it in the app store!
