Idle problem NA
Re: Idle problem NA
Maybe a vacuum problem?
Re: Idle problem NA
Have you checked the ignition timing setting & other settings? Also disconnect battery, pump brake pedal a few times, then reconnect battery to clear ECU. Here's some more detail on setting idle when there's an idle problem: viewtopic.php?f=76&t=60434
- YanMa YatTai
Re: Idle problem NA
^ that link has good advice. I just about went through each one of those items in the list without knowing that such a list existed!
There are so many possible causes. Mine had the same issues as yours (idle at 1500rpm).
I had a cracked crossover tube, bad injectors and bad ISCV. Cleaning the ISCV helped, but it wasnt until it was replaced that my idle was OK.
Re: Idle problem NA
Did you do anything prior to noticing the bump in idle?
What happens when you block off the inlet tube to your idle control solenoid?
